Anyone use lightweight batteries? #3098632
12/01/22 11:34 AM
12/01/22 11:34 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Looks like there are some smaller AGM and lithium-type automotive batteries that can help drop some lbs vs standard replacement batteries. Has anyone here used them? If so, what have you seen re durability, holding charge, etc.? Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3098636
12/01/22 11:58 AM
12/01/22 11:58 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Most of the smaller AGM batteries are just motorcycle batteries with a post adapter. They also puff up the cranking amps by rating them with a 5 second test vs 15, you can add about 40% to the CCA number when doing it that way.
I have zero experience with the Lithium stuff. All I know is the ones with prismatic cells are supposed to be less likely to catch fire!
68 Barracuda Formula S 340
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3098637
12/01/22 12:01 PM
12/01/22 12:01 PM
AndyF Offline
AndyF  Offline
I used a half sized battery in my Duster. I fabricated a half size battery tray for it. Worked fine in that car but that car was kept in a heated garage and I had a Denso alternator that held 14 volts at idle.
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3098638
12/01/22 12:05 PM
12/01/22 12:05 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I run an Odyssey PC925 AGM which is about 1/2 way there in terms of size and weight. 24lbs. I use it because it fits in my gutted repro batt case. 10.2:1 440 Mopar, cranks it over just fine.
Re: Anyone use lightweight batteries? [Re: Pacnorthcuda] #3098644
12/01/22 12:29 PM
12/01/22 12:29 PM
Loudoun County, VA
Loudoun County, VA
In my application it would be going in the trunk-mounted Moroso battery box; don't care what it looks like, only what it works like. wink
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3098651
12/01/22 12:57 PM
12/01/22 12:57 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Like you Brad I drive my car to the track and do not have a support vehicle, for that reason I struggle with downsizing a battery. I rely on it to cool the car between passes. I also know from previous mishaps that I can drive my car over an hour with no alternator using a standard yellow top optima.
Re: Anyone use lightweight batteries? [Re: Bad340fish] #3098657
12/01/22 01:08 PM
12/01/22 01:08 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run the same Braile battery as pictured above in my race car and have the Odyssey PC25 batteries in my gutted resto battery cases in my street cars.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Anyone use lightweight batteries? [Re: 6PKRTSE] #3098691
12/01/22 03:03 PM
12/01/22 03:03 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have been using a GoLithium 16v battery. No alternator
Im only racing 1/8 and tow up / drive back but it can make it two passes if needed. Most times i am charging it after every pass. It does take about 15? min to charg in that situation. If run down a lot it takes about 30-40 min to fully charge. Works great for a race car and only weights 8 lbs. It can be mounted in passenger compartment so it helps to shorten the wiring and lose even more weight
....BAD A$$ STREET CAR.....
Re: Anyone use lightweight batteries? [Re: n20mstr] #3098716
12/01/22 04:45 PM
12/01/22 04:45 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
been using half size AGM batteries for years Odyssey or similar in my Satellite , it is mounted in factory position . Current battery is coming up for 4 years old . It feels like it might be hitting the limit , last one lasted similar , as it now is a hair slower cranking . They often dont give much warning before they die . I have used the same size as Andy but that was ok for 2-3 years but always felt like it was only just enough .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Anyone use lightweight batteries? [Re: tex013] #3098717
12/01/22 04:48 PM
12/01/22 04:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Street car/ street strip car, I wouldn’t even bother fooling with it. Unlikely it would show up on an ET slip.
I use the biggest honkin interstate battery I can fit in my box, nice 1 wire alternator, and life is good, even running electric fan and water pump going rounds
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3098719
12/01/22 04:53 PM
12/01/22 04:53 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Most of my cars are street cars that I race....That said, I have tried light weight alternators and batteries...I found neither were enough for street/strip duty with all of todays electronics....I like the red tops a lot and is usually what I use, they are 34lbs....and rated 900ccr
I use a Mechman 170 amp alternator: (best alternator at an idle I have ever used)
https://www.mechman.com/alternators...85-gm-natural-finish-includes-2-pulleys/
And for the big damn Hemi I went to a XS Battery 3400 at 46lbs and rated at 1150ccr
https://www.summitracing.com/parts/xsp-d3400r?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+X&utm_term=4581527515794457&utm_content=GSAPI+5ba2912166b67
I can let the fans run till the motor is cool and fire the car right up...smaller batteries, no way....And the Lithium batteries require a very special charge, and I will not put one in a car. They require constant current till a specific voltage, and then they need switched to low current constant voltage.....I would never just charge one with an alternator, its asking for trouble when over charged. If you don't run an alternator and have a Lithium charger, life is good...But for a street strip car, I have tried many of the lighter batteries, and they just don't have the amps for a big engine.
Biggest Braille battery is 945ccr and 45lbs in AGM form....So not much difference in weight for me....
Re: Anyone use lightweight batteries? [Re: Dragula] #3098726
12/01/22 05:30 PM
12/01/22 05:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
For what its worth if you run fans and stuff between rounds and you want to run an Optima the Yellow Top is what is best for that. Not that the red one won't work but the yellow is has more cycling capability. Downside is that it is a little heavier and has less CCA on the sticker. My last yellow top lasted 10 years and I only removed it because the seal around the negative post started to let a little gas out and corroded my terminal. I gave it to a friend of uses it on a trailer for a winch.
Re: Anyone use lightweight batteries? [Re: Bad340fish] #3098728
12/01/22 05:50 PM
12/01/22 05:50 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Full size battery and Chevy 60 amp one wire alternator for this guy.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3098816
12/01/22 11:30 PM
12/01/22 11:30 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Snyder motorsports This is what I use
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Anyone use lightweight batteries? [Re: W.I.N. Racing] #3098864
12/02/22 08:43 AM
12/02/22 08:43 AM
Loudoun County, VA
Loudoun County, VA
All good info up
A lightweight AGM would be my choice; lithium batteries are off the list now
Currently have standard-size Optima Red Top
The idea is to do the smaller battery & fiberglass bumpers w/ aluminum brackets swap at the same time to help offset additional weight gained from switching to the Strange S-60 and some other changes that porked up The MoPig a bit. The driver can stand to get back on a healthier diet and shed some previously-lost weight, as well.
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3098880
12/02/22 09:57 AM
12/02/22 09:57 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I'm not sure there's a correct answer but if you're really into saving weight of course go with a lithium high voltage and then reduce that to certain components like O2's etc THEN placing that for minimal wire lengths is the ultimate in saving weight. As weight conscious as i was building i decided to stay AGM 12v which actually is heavy at 55lbs. (XS battery) but it has exceptional power and reserve. This is despite some great suggestions from well-accomplished people here. Part of my decision was that i already had all the foundation and battery. A few of my heads-up buddies do the smaller 16V XS 30lb battery and only charge in the pits with no alternator. hope this helps.
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3098882
12/02/22 10:06 AM
12/02/22 10:06 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted by Brad_Haak
All good info up
I went from an 8.75 to a Dana years ago, saw zip on the slip. This on a car I raced all the time, well sorted.
Gonna be doing same thing with current car, not expecting anything to show up different.
1.41 best 60 foot
6.56 at 104.17
Re: Anyone use lightweight batteries? [Re: B3422W5] #3098886
12/02/22 10:23 AM
12/02/22 10:23 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Adding pic
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3098927
12/02/22 12:39 PM
12/02/22 12:39 PM
AndyF Offline
AndyF  Offline
A clamp on amp meter is highly recommended when you start messing with this stuff. You can get a cheap one for $50 or so off Amazon or HoBo Freight.
I used my clamp on to verify the charging amps as well as all of the ground circuits on my Duster. Typically the small battery would recharge in 2 or 3 minutes after a start. I could watch the amp draw fall as the battery charged back up. What I learned with the small battery was that you had to run the engine for a couple of minutes before starting it again or else you could draw it down too far. But the Duster had EFI with coil on plug, high pressure fuel pump, etc. Also EFI was fairly sensitive to cranking volts so I had to be careful to keep the battery charged. Your car will be a little less sensitive to cranking voltage but you'll need to keep an eye on it if you go with a smaller battery.
Re: Anyone use lightweight batteries? [Re: AndyF] #3099093
12/02/22 10:21 PM
12/02/22 10:21 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
All my cars have alternators. I used the 13.5 pound dynabatt for many years, hidden inside a gutted restoration battery in my stock appearing gtx, then transfered it later to my street car. I had 2 of them that lasted about 5 years each, and one that went 9 years. I did not have an electric fan or water pump, so starting was all that mattered.
Then in 2017 I switched to lithium. 5 pounds. See my post in Cabs thread. https://board.moparts.org/ubbthread...teries-which-one-to-use.html#Post3098770
I have also used the powersports battery. They work, but don't last too long and are heavier than lithium. About 17 lbs.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
