Re: Racing 12 Volt batteries, which one to use?
[Re: dvw]
#3098862
12/02/22 08:25 AM
12/02/22 08:25 AM
Posts: 149 Connellsville
71Demon528
Connellsville
I put a single 16 volt XS battery in to replace 2 AGM 12volt batteries. Best thing I ever did. Starts way better. Will go rounds without charging if needed. Doug Agreed with Doug. 16 volt XS battery D1600 model. Well worth the upgrade. With the right alternator, you won't have to charge in between rounds, at least I don't.
[Re: Gabby63]
#3099087
12/02/22 10:00 PM
12/02/22 10:00 PM
Posts: 7,499 Minnesota
Hemi_Joel
Minnesota
Cab, as you know weight is everything in a heads up car. The lithium battery opens up the opportunity for reconsidering old conventions. I use a 5 pound Antigravity ATX20-HD battery. It has 900 CCA, and spins my 13:1 hemi like the plugs are out of it. The case is 6.89 x 3.4 x 5.12 inches Since it is so small and so light, I mounted it on the inside of the drivers side frame rail , between the frame rail and the transmission. Transferring it to the trunk would not benefit weight distribution because it is so light. That eliminates all the weight of cables extending to the trunk as well as the weight savings of the battery itself. Then I mounted the cut-off switch under the drivers side front floor, with the shaft protruding vertically thru the floor into the cabin. Then I used a 5/16" x .030 stainless tube from the switch, out the back as a light weight remote control. This set up saves gobs of weight, and I can operate the switch from the drivers seat. They say these batterys are supposed to last 10 years, but my battery failed after 4 years. When I notified Antigravity, they sent me a replacement for 1/2 price, so I'm happy. They said I can charge it off the alternator, no problem. But when using a 110 volt charger, it has to be a Li specific charger.
![Name: rod in cockpit.jpg
ID: 472528 rod in cockpit.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/472528/filename/rod in cockpit.jpg) ![Name: push off.jpg
ID: 472529 push off.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/472529/filename/push off.jpg)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
