Anyone use lightweight batteries?
#3098632
12/01/22 11:34 AM
12/01/22 11:34 AM
Posts: 1,154 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Looks like there are some smaller AGM and lithium-type automotive batteries that can help drop some lbs vs standard replacement batteries. Has anyone here used them? If so, what have you seen re durability, holding charge, etc.? Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Anyone use lightweight batteries?
[Re: Brad_Haak]
#3098636
12/01/22 11:58 AM
12/01/22 11:58 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
Most of the smaller AGM batteries are just motorcycle batteries with a post adapter. They also puff up the cranking amps by rating them with a 5 second test vs 15, you can add about 40% to the CCA number when doing it that way.
I have zero experience with the Lithium stuff. All I know is the ones with prismatic cells are supposed to be less likely to catch fire!
68 Barracuda Formula S 340
[Re: Pacnorthcuda]
#3098644
12/01/22 12:29 PM
12/01/22 12:29 PM
Brad_Haak
Loudoun County, VA
In my application it would be going in the trunk-mounted Moroso battery box; don't care what it looks like, only what it works like.
[Re: Brad_Haak]
#3098651
12/01/22 12:57 PM
12/01/22 12:57 PM
Bad340fish
Tulsa OK
Like you Brad I drive my car to the track and do not have a support vehicle, for that reason I struggle with downsizing a battery. I rely on it to cool the car between passes. I also know from previous mishaps that I can drive my car over an hour with no alternator using a standard yellow top optima.
[Re: Bad340fish]
#3098657
12/01/22 01:08 PM
12/01/22 01:08 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I run the same Braile battery as pictured above in my race car and have the Odyssey PC25 batteries in my gutted resto battery cases in my street cars.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3098691
12/01/22 03:03 PM
12/01/22 03:03 PM
Posts: 4,696 On the parachute mount
n20mstr
I have been using a GoLithium 16v battery. No alternator Im only racing 1/8 and tow up / drive back but it can make it two passes if needed. Most times i am charging it after every pass. It does take about 15? min to charg in that situation. If run down a lot it takes about 30-40 min to fully charge. Works great for a race car and only weights 8 lbs. It can be mounted in passenger compartment so it helps to shorten the wiring and lose even more weight
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3098716
12/01/22 04:45 PM
12/01/22 04:45 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
been using half size AGM batteries for years Odyssey or similar in my Satellite , it is mounted in factory position . Current battery is coming up for 4 years old . It feels like it might be hitting the limit , last one lasted similar , as it now is a hair slower cranking . They often dont give much warning before they die . I have used the same size as Andy but that was ok for 2-3 years but always felt like it was only just enough .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3098717
12/01/22 04:48 PM
12/01/22 04:48 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Street car/ street strip car, I wouldn’t even bother fooling with it. Unlikely it would show up on an ET slip. I use the biggest honkin interstate battery I can fit in my box, nice 1 wire alternator, and life is good, even running electric fan and water pump going rounds
[Re: Brad_Haak]
#3098719
12/01/22 04:53 PM
12/01/22 04:53 PM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
Most of my cars are street cars that I race....That said, I have tried light weight alternators and batteries...I found neither were enough for street/strip duty with all of todays electronics....I like the red tops a lot and is usually what I use, they are 34lbs....and rated 900ccr I use a Mechman 170 amp alternator: (best alternator at an idle I have ever used) https://www.mechman.com/alternators...85-gm-natural-finish-includes-2-pulleys/And for the big damn Hemi I went to a XS Battery 3400 at 46lbs and rated at 1150ccr https://www.summitracing.com/parts/xsp-d3400r?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+X&utm_term=4581527515794457&utm_content=GSAPI+5ba2912166b67 I can let the fans run till the motor is cool and fire the car right up...smaller batteries, no way....And the Lithium batteries require a very special charge, and I will not put one in a car. They require constant current till a specific voltage, and then they need switched to low current constant voltage.....I would never just charge one with an alternator, its asking for trouble when over charged. If you don't run an alternator and have a Lithium charger, life is good...But for a street strip car, I have tried many of the lighter batteries, and they just don't have the amps for a big engine. Biggest Braille battery is 945ccr and 45lbs in AGM form....So not much difference in weight for me....
[Re: Dragula]
#3098726
12/01/22 05:30 PM
12/01/22 05:30 PM
Bad340fish
Tulsa OK
For what its worth if you run fans and stuff between rounds and you want to run an Optima the Yellow Top is what is best for that. Not that the red one won't work but the yellow is has more cycling capability. Downside is that it is a little heavier and has less CCA on the sticker. My last yellow top lasted 10 years and I only removed it because the seal around the negative post started to let a little gas out and corroded my terminal. I gave it to a friend of uses it on a trailer for a winch.
[Re: Bad340fish]
#3098728
12/01/22 05:50 PM
12/01/22 05:50 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Full size battery and Chevy 60 amp one wire alternator for this guy.
[Re: Brad_Haak]
#3098816
12/01/22 11:30 PM
12/01/22 11:30 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
Snyder motorsports This is what I use
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3098864
12/02/22 08:43 AM
12/02/22 08:43 AM
Brad_Haak
Loudoun County, VA
All good info A lightweight AGM would be my choice; lithium batteries are off the list now Currently have standard-size Optima Red Top The idea is to do the smaller battery & fiberglass bumpers w/ aluminum brackets swap at the same time to help offset additional weight gained from switching to the Strange S-60 and some other changes that porked up The MoPig a bit. The driver can stand to get back on a healthier diet and shed some previously-lost weight, as well.
[Re: Brad_Haak]
#3098882
12/02/22 10:06 AM
12/02/22 10:06 AM
B3422W5
Portage,michigan
All good info A lightweight AGM would be my choice; lithium batteries are off the list now Currently have standard-size Optima Red Top The idea is to do the smaller battery & fiberglass bumpers w/ aluminum brackets swap at the same time to help offset additional weight gained from switching to the Strange S-60 and some other changes that porked up The MoPig a bit. The driver can stand to get back on a healthier diet and shed some previously-lost weight, as well. I went from an 8.75 to a Dana years ago, saw zip on the slip. This on a car I raced all the time, well sorted. Gonna be doing same thing with current car, not expecting anything to show up different.
[Re: AndyF]
#3099093
12/02/22 10:21 PM
12/02/22 10:21 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
All my cars have alternators. I used the 13.5 pound dynabatt for many years, hidden inside a gutted restoration battery in my stock appearing gtx, then transfered it later to my street car. I had 2 of them that lasted about 5 years each, and one that went 9 years. I did not have an electric fan or water pump, so starting was all that mattered. Then in 2017 I switched to lithium. 5 pounds. See my post in Cabs thread. https://board.moparts.org/ubbthread...teries-which-one-to-use.html#Post3098770I have also used the powersports battery. They work, but don't last too long and are heavier than lithium. About 17 lbs.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
