Got my hood on! Need a carb to hood pan idea? #3094548
11/16/22 01:05 AM
11/16/22 01:05 AM
Wisconsin
wkroncke17 Offline OP
Wisconsin
All,
Finally got my hood painted and on!
Looking for ideas and pics of a good way to have the hood sealed to a pan and get air directly to the carb.
It’s a Glasstek fiberglass hood, it’s completely open under the scoop.
When I had a stock hood, I cut a coffee can size hole and made a foam ring to seal to the bottom of the hood.
Going to hopefully come up with an idea to fabricate or purchase something nice.
Thanks all!
Wally.
Re: Got my hood on! Need a carb to hood pan idea? [Re: wkroncke17] #3094604
11/16/22 10:54 AM
11/16/22 10:54 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
nice car
Re: Got my hood on! Need a carb to hood pan idea? [Re: one bad fish] #3094608
11/16/22 11:12 AM
11/16/22 11:12 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
My comments and pics HERE may give you an idea for your setup...
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Got my hood on! Need a carb to hood pan idea? [Re: Brad_Haak] #3094617
11/16/22 11:50 AM
11/16/22 11:50 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Depending on carb height and whether you run an air cleaner...
A large square of aluminum attached to the air cleaner base, foam perimeter to seal to the hood.
Or, same deal attached to top of the carb with a U-bracket/stud/nut.
Or, bond the aluminum to the hood itself, hole of appropriate size/location to clear carb/cleaner
Re: Got my hood on! Need a carb to hood pan idea? [Re: Brad_Haak] #3094618
11/16/22 11:53 AM
11/16/22 11:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
.030" aluminum. Bend at a 90 on the edge for stiffness. Taper the foam to fill the gap. Cheap and light.
Doug
Re: Got my hood on! Need a carb to hood pan idea? [Re: wkroncke17] #3094652
11/16/22 01:27 PM
11/16/22 01:27 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My Dart has an AAR bolt on six pack hood, the opening is huge, so I fabricated a plate that is glued to the hood. Then I made an air pan that is attached to an air cleaner base, then added foam to seal it to the hood.
Re: Got my hood on! Need a carb to hood pan idea? [Re: justinp61] #3094755
11/16/22 05:23 PM
11/16/22 05:23 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Heres mine . Its actually nade of plywood . Bolted to a air cleaner base. Foam to seal . This is under a six pack scoop/ hood
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
