Re: Got my hood on! Need a carb to hood pan idea?
[Re: one bad fish]
#3094608
11/16/22 11:12 AM
11/16/22 11:12 AM
Posts: 1,131 Loudoun County, VA
Brad_Haak
Loudoun County, VA
My comments and pics HERE may give you an idea for your setup...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3094618
11/16/22 11:53 AM
11/16/22 11:53 AM
Posts: 9,843 MI, usa
dvw
MI, usa
.030" aluminum. Bend at a 90 on the edge for stiffness. Taper the foam to fill the gap. Cheap and light. Doug
[Re: justinp61]
#3094755
11/16/22 05:23 PM
11/16/22 05:23 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Heres mine . Its actually nade of plywood . Bolted to a air cleaner base. Foam to seal . This is under a six pack scoop/ hood
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
