New best with my Edelbrock headed 408
#3069275
08/18/22 04:09 PM
08/18/22 04:09 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not the time of year I expected to do this but I ran a new best 6.03 at Quaker City last weekend with this combo. This thing has really surpassed my expectations and we aren’t even into Fall yet. The car is a little lighter this year with a factory 360 block and the driver lost a few pounds so it’s now a touch under 2850 pounds. Still shifting at 6700 rpm and it’s really pulling so I may bump the shift rpm up when we get some killer weather. My weather station is reading about 400 feet or so low but I don’t want to change the calibration and lose my info since I’m the only one using my info it doesn’t really matter.
Re: New best with my Edelbrock headed 408
[Re: tboomer]
#3069287
08/18/22 04:26 PM
08/18/22 04:26 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Pretty good John! What are you using for fuel? Alcohol and a 900 (1000) cfm carb.
[Re: pittsburghracer]
#3069299
08/18/22 05:05 PM
08/18/22 05:05 PM
Posts: 11,631 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
1200' and uphill IIRC. I remember it being sloooo there compared to what we're used to down here in the flatlands.
[Re: Dragula]
#3069307
08/18/22 05:20 PM
08/18/22 05:20 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
For that ET, your MPH is 1-2 low....I would look at jetting it a little one way or the other. Mine is typically 112-113 in the 6.0 range...Had one time slip that was 115.44 and 6.002.... How a smallblock car ET’s compared to a big inch big block is obviously gonna be different. I doubt yours had a 1.27 short time, as an example. Lot, lot smaller motor
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: J_BODY]
#3069376
08/18/22 09:50 PM
08/18/22 09:50 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks buddy. Now I gotta lean on my Indy headed engine harder when I rebuilt it so it isn’t embarrassed. Lol
[Re: Red440]
#3069778
08/20/22 06:52 AM
08/20/22 06:52 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks guys it’s been a blast this year. At 66 years old you gotta go while you are still able.
#3069811
08/20/22 09:46 AM
08/20/22 09:46 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
nice
[Re: one bad fish]
#3069983
08/20/22 07:33 PM
08/20/22 07:33 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
What do you think the methanol is worth? I think a friends small block car is 3 tenths faster in the 1/4 on methanol vs gas. Have you ever run it on gas?
68 Barracuda Formula S 340
[Re: Bad340fish]
#3070020
08/20/22 09:30 PM
08/20/22 09:30 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What do you think the methanol is worth? I think a friends small block car is 3 tenths faster in the 1/4 on methanol vs gas. Have you ever run it on gas? Not on this combo as I’ve been running alcohol for 6-7 years at least. My last gas engine was a W2 engine that ran 9.82 on BP 93 pump gas.
#3070022
08/20/22 09:33 PM
08/20/22 09:33 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Ran a 6.04 and 6.05 during time trials at keystone today on a hot nasty day. Rain moved in and they are trying to dry the track for our night of fire activities. Humidity is fighting them.
#3070365
08/22/22 08:46 AM
08/22/22 08:46 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
