New best with my Edelbrock headed 408
#3069275
08/18/22 04:09 PM
08/18/22 04:09 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not the time of year I expected to do this but I ran a new best 6.03 at Quaker City last weekend with this combo. This thing has really surpassed my expectations and we aren’t even into Fall yet. The car is a little lighter this year with a factory 360 block and the driver lost a few pounds so it’s now a touch under 2850 pounds. Still shifting at 6700 rpm and it’s really pulling so I may bump the shift rpm up when we get some killer weather. My weather station is reading about 400 feet or so low but I don’t want to change the calibration and lose my info since I’m the only one using my info it doesn’t really matter.
Re: New best with my Edelbrock headed 408
[Re: tboomer]
#3069287
08/18/22 04:26 PM
08/18/22 04:26 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Pretty good John! What are you using for fuel? Alcohol and a 900 (1000) cfm carb.
[Re: pittsburghracer]
#3069299
08/18/22 05:05 PM
08/18/22 05:05 PM
Posts: 11,655 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
1200' and uphill IIRC. I remember it being sloooo there compared to what we're used to down here in the flatlands.
[Re: Dragula]
#3069307
08/18/22 05:20 PM
08/18/22 05:20 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
For that ET, your MPH is 1-2 low....I would look at jetting it a little one way or the other. Mine is typically 112-113 in the 6.0 range...Had one time slip that was 115.44 and 6.002.... How a smallblock car ET’s compared to a big inch big block is obviously gonna be different. I doubt yours had a 1.27 short time, as an example. Lot, lot smaller motor
[Re: J_BODY]
#3069376
08/18/22 09:50 PM
08/18/22 09:50 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks buddy. Now I gotta lean on my Indy headed engine harder when I rebuilt it so it isn’t embarrassed. Lol
[Re: Red440]
#3069778
08/20/22 06:52 AM
08/20/22 06:52 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks guys it’s been a blast this year. At 66 years old you gotta go while you are still able.
#3069811
08/20/22 09:46 AM
08/20/22 09:46 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
nice
[Re: one bad fish]
#3069983
08/20/22 07:33 PM
08/20/22 07:33 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
What do you think the methanol is worth? I think a friends small block car is 3 tenths faster in the 1/4 on methanol vs gas. Have you ever run it on gas?
68 Barracuda Formula S 340
[Re: Bad340fish]
#3070020
08/20/22 09:30 PM
08/20/22 09:30 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What do you think the methanol is worth? I think a friends small block car is 3 tenths faster in the 1/4 on methanol vs gas. Have you ever run it on gas? Not on this combo as I’ve been running alcohol for 6-7 years at least. My last gas engine was a W2 engine that ran 9.82 on BP 93 pump gas.
#3070022
08/20/22 09:33 PM
08/20/22 09:33 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Ran a 6.04 and 6.05 during time trials at keystone today on a hot nasty day. Rain moved in and they are trying to dry the track for our night of fire activities. Humidity is fighting them.
#3070365
08/22/22 08:46 AM
08/22/22 08:46 AM
Posts: 13,384 Marion, South Carolina [><]
an8sec70cuda
