Which stroker kit for a 493 RB 650-700 HP? #306104
05/02/09 10:26 PM
05/02/09 10:26 PM
Maryland
Dads426 Offline OP
Dads426  Offline OP
Maryland
We (Kevins440) are going to put together another 493 shortblock for the Bounty Hunters Dodge. Filled stock block, aftermarket steel main caps, maybe a girdle (clearance issues with center link if we don't raise the engine slightly; need a new motor plate if we do), flat-top pistons for 12-1 compression with 440-1 heads. Should I buy a kit from Scat, 440 Source, Eagle, or piece together an assembly using a Scat crank, Manley rods, JE pistons? Any suggestions if I piece together a kit or what should I look out for in the preassembled kits?
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: Dads426] #306105
05/02/09 10:44 PM
05/02/09 10:44 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
You have a pm.
RIP Monte Smith
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: CompWedgeEngines] #306106
05/02/09 10:58 PM
05/02/09 10:58 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
at 700 horses i'd go with the Source kit. their cranks are actually stronger than an Eagle( paid good money to have this checked). the sources KB pistons will put you right on the money for the 12;1 comp ratio. the only drawback is having to radius your bearings to make them fit but once done everything will be fine.
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: rebel] #306107
05/02/09 11:24 PM
05/02/09 11:24 PM
AndyF Offline
AndyF  Offline
No need to radius the bearings if you buy the right ones. I have a 440Source crank in my 505 and the bearings fit fine right out of the box.
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: rebel] #306108
05/03/09 03:00 PM
05/03/09 03:00 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
I think its only the main bearings in a b-block you have to bevel.As the limited main bearing choices.
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: Dads426] #306109
05/03/09 04:26 PM
05/03/09 04:26 PM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
Muscle Motors also offer very good prices like 440 source. Very good customer service. I bought one from them and they were very helful with everything. My combo made 761hp and it works great no problems at all!!
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: hugo] #306110
05/03/09 10:03 PM
05/03/09 10:03 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: AndyF] #306111
05/04/09 01:23 AM
05/04/09 01:23 AM
WA 98043
thecarfarmer Offline
WA 98043
Don't mean to start one of those 'internet pissing matches', but I can tell ya' that the Source cranks don't always work without chamfering the bearings just because you use the narrow ones (Clevite 743HN - what they provided in my kit).
Unless you're using something else - if so, please share the info; I'll be happy to install a different part if it's a 'drop in' whenever I freshen the motor!
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: AndyF] #306112
05/04/09 03:01 AM
05/04/09 03:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
what are the right bearings andy? i have a B engine & have to chamfer both the mains & the rods to fit mine. luckily i've done this a few times now & generally get the right amount of bevel first time, but it still takes time getting it right.
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: rebel] #306113
05/04/09 04:13 AM
05/04/09 04:13 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Hughes
Mopar Performance
Re: Which stroker kit for a 493 RB 650-700 HP? [Re: Dads426] #306114
05/04/09 07:21 AM
05/04/09 07:21 AM
Northeast Georgia
47hudson Offline
47hudson  Offline
Northeast Georgia
We have been running that engine since 05 440source kit 493" 440-1 heads with only a little cleaning no port work, 12-1 comp. flat tappet cam etc. Best so far was 9.96 @ 134 in a 3500lb brick. 440source kit dropped in with no work on the crank or bearings and has been hammered on just about every week.
