at 700 horses i'd go with the Source kit. their cranks are actually stronger than an Eagle( paid good money to have this checked). the sources KB pistons will put you right on the money for the 12;1 comp ratio. the only drawback is having to radius your bearings to make them fit but once done everything will be fine.
