No need to radius the bearings if you buy the right ones. I have a 440Source crank in my 505 and the bearings fit fine right out of the box.
Don't mean to start one of those 'internet pissing matches', but I can tell ya' that the Source cranks don't always work without chamfering the bearings just because you use the narrow ones (Clevite 743HN - what they provided in my kit).
Unless you're using something else - if so, please share the info; I'll be happy to install a different part if it's a 'drop in' whenever I freshen the motor!
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
