Need help with 440 (Long) #305943
05/02/09 09:13 PM
05/02/09 09:13 PM
Indiana
soul challenger Offline OP
Indiana
I have a 440 in a 74 Charger. This engine has been in this car for 4 years with no problems. I got it out this year and it ran great. On the way home from a show it started to run bad. It will idle OK in park, but when I put it in gear it won't hardly idle and once it warms up it loses fuel pressure. Going down the road it runs great until you have to stop, then it wants to die. I figured it was the fuel pump. I replaced it and checked the pump push rod and it looks good. I also checked the fuel filter and it is fine as well. Any ideas on what the problem may be? Thanks
"She ain't revved till the rods are thrown." DBT
Re: Need help with 440 (Long) [Re: soul challenger] #305944
05/02/09 09:20 PM
05/02/09 09:20 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You said it loses fuel pressure. Are you running an electric pump and do you have a fuel pressure gauge hooked up. It sounds like a carb issue to me.
Re: Need help with 440 (Long) [Re: stumpy] #305945
05/02/09 09:27 PM
05/02/09 09:27 PM
Indiana
Indiana
It is a mechanical fuel pump. I have an inline gauge. It has pressure when cold, the warmer it gets the less pressure it has, goes to zero. Thank you.
Re: Need help with 440 (Long) [Re: soul challenger] #305946
05/02/09 09:28 PM
05/02/09 09:28 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Do you have a press guage at the carb feed line?
That will help you figure out if it is a carb problem of a fuel feed problem.
Ever drop the fuel tank (crud)?
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Need help with 440 (Long) [Re: wingman] #305947
05/02/09 09:31 PM
05/02/09 09:31 PM
Indiana
Indiana
I had the tank out a few years ago and it looked brand new inside. That may be the next thing I do is check the tank.
Re: Need help with 440 (Long) [Re: soul challenger] #305948
05/02/09 09:36 PM
05/02/09 09:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
is it a fluid filled gauge?
Re: Need help with 440 (Long) [Re: soul challenger] #305949
05/02/09 09:37 PM
05/02/09 09:37 PM
carb/vacuum leak/ EDIT possibley plugs/wires
Re: Need help with 440 (Long) [Re: RapidRobert] #305950
05/03/09 09:01 AM
05/03/09 09:01 AM
Central NC
gch Offline
gch  Offline
Central NC
I would take a look inside the carb itself.Other ideas are pickup sock in the tank partially clogged and replace your fuel filter also.
Plugs and wires ahould be inspected also.
Re: Need help with 440 (Long) [Re: gch] #305951
05/03/09 09:15 AM
05/03/09 09:15 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Check for cracked hoses from tank to carb if you have any as it may be sucking air.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Need help with 440 (Long) [Re: MY340] #305952
05/03/09 10:04 AM
05/03/09 10:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that's what I'd do 1st. a crack line will do that. The one at the tank to the main line check 1st.
Re: Need help with 440 (Long) [Re: Mr.Yuck] #305953
05/03/09 07:04 PM
05/03/09 07:04 PM
Indiana
Indiana
Thanks alot for the help. I thought the rubber line from the tank to the main line was kinked, replaced it with braided hose and it still won't run right.
Re: Need help with 440 (Long) [Re: soul challenger] #305954
05/03/09 07:48 PM
05/03/09 07:48 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
did you ck the hose back at the tank for any splits? also the sock inside the tank could be getting clogged up with silt... good luck dan
Re: Need help with 440 (Long) [Re: soul challenger] #305955
05/03/09 08:24 PM
05/03/09 08:24 PM
Kirkland, Washington
Pacnorthcuda Offline
you might also want to check to ensure you're not creating a vacuum in the tank. When it dies open the gas cap and see if is sucks air---Probably not the problem, but its such and easy check you should rule it out.
Re: Need help with 440 (Long) [Re: Pacnorthcuda] #305956
05/05/09 06:27 AM
05/05/09 06:27 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Check to see if you have the 4 atmospheric breather tubes blocked off on the fuel tank (from the underside) I blocked mine off when I installed the tank on my 70 Charger and I lost fuel pressure because the fuel tank was sucking it back from the motor. Make sure you have proper vent lines. Drive around with a 1/4 tank of gas and some duct tape with holes in it on the gas cap area and see if the car runs right. Late at night so fuel doesnt go sloshing in and out of the neck tube.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
