Need help with 440 (Long)
#305943
05/02/09 09:13 PM
05/02/09 09:13 PM
Posts: 86 Indiana
soul challenger
Indiana
I have a 440 in a 74 Charger. This engine has been in this car for 4 years with no problems. I got it out this year and it ran great. On the way home from a show it started to run bad. It will idle OK in park, but when I put it in gear it won't hardly idle and once it warms up it loses fuel pressure. Going down the road it runs great until you have to stop, then it wants to die. I figured it was the fuel pump. I replaced it and checked the pump push rod and it looks good. I also checked the fuel filter and it is fine as well. Any ideas on what the problem may be? Thanks
"She ain't revved till the rods are thrown." DBT
Re: Need help with 440 (Long)
[Re: stumpy]
#305945
05/02/09 09:27 PM
05/02/09 09:27 PM
Posts: 86 Indiana
soul challenger
Indiana
It is a mechanical fuel pump. I have an inline gauge. It has pressure when cold, the warmer it gets the less pressure it has, goes to zero. Thank you.
[Re: soul challenger]
#305946
05/02/09 09:28 PM
05/02/09 09:28 PM
Posts: 3,381 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Do you have a press guage at the carb feed line?
That will help you figure out if it is a carb problem of a fuel feed problem.
Ever drop the fuel tank (crud)?
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#305947
05/02/09 09:31 PM
05/02/09 09:31 PM
Posts: 86 Indiana
soul challenger
Indiana
I had the tank out a few years ago and it looked brand new inside. That may be the next thing I do is check the tank.
#305948
05/02/09 09:36 PM
05/02/09 09:36 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
is it a fluid filled gauge?
#305949
05/02/09 09:37 PM
05/02/09 09:37 PM
RapidRobert
carb/vacuum leak/ EDIT possibley plugs/wires
[Re: gch]
#305951
05/03/09 09:15 AM
05/03/09 09:15 AM
Posts: 5,270 Missouri
MY340
Missouri
Check for cracked hoses from tank to carb if you have any as it may be sucking air.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: MY340]
#305952
05/03/09 10:04 AM
05/03/09 10:04 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
that's what I'd do 1st. a crack line will do that. The one at the tank to the main line check 1st.
[Re: Mr.Yuck]
#305953
05/03/09 07:04 PM
05/03/09 07:04 PM
Posts: 86 Indiana
soul challenger
Indiana
Thanks alot for the help. I thought the rubber line from the tank to the main line was kinked, replaced it with braided hose and it still won't run right.
[Re: Pacnorthcuda]
#305956
05/05/09 06:27 AM
05/05/09 06:27 AM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
Check to see if you have the 4 atmospheric breather tubes blocked off on the fuel tank (from the underside) I blocked mine off when I installed the tank on my 70 Charger and I lost fuel pressure because the fuel tank was sucking it back from the motor. Make sure you have proper vent lines. Drive around with a 1/4 tank of gas and some duct tape with holes in it on the gas cap area and see if the car runs right. Late at night so fuel doesnt go sloshing in and out of the neck tube.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
