U joint question - swapped center section #305757
05/02/09 05:33 PM
05/02/09 05:33 PM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
I just replaced the center section in my Road Runner, and didn't notice until I was putting the driveshaft back in that the yokes are different.
The oneI replaced it with has a larger yoke.
Is there a different u-joint that I can swap to make it work? If so, do you have a part number?
Re: U joint question - swapped center section [Re: Prostock] #305758
05/02/09 05:40 PM
05/02/09 05:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
No part number off hand, but there is a conversion joint available from CarQuest, and Autozone,....it's a cheapy,...I'd recommend you stop by a driveshaft shop and get the Splicer brand, unless CQ or AZ can get can assure you of the Splicer brand,....I have two cars running the conversion joints,...no problems,......also contact DrDiff here on Moparts, I believe he has conversion joints as well
Re: U joint question - swapped center section [Re: Prostock] #305759
05/02/09 05:40 PM
05/02/09 05:40 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
I think this is the u-joint you are taking about. Good luck
http://www.moparts.org/Tech/Archive/shaft/4.html
Re: U joint question - swapped center section [Re: 68Fastback] #305760
05/02/09 05:42 PM
05/02/09 05:42 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Jess if I remember correctly the Dart has a conversion u joint on it?
Re: U joint question - swapped center section [Re: 69DartGT] #305761
05/02/09 05:48 PM
05/02/09 05:48 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Yes it does, I noticed that. I had never seen one before so threw me off for a bit.
Re: U joint question - swapped center section [Re: 68Fastback] #305762
05/02/09 06:00 PM
05/02/09 06:00 PM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
The one I took out has a smaller yoke on it than the one I put in. Is that the conversion ujoint for going that way?
Re: U joint question - swapped center section [Re: Prostock] #305763
05/02/09 06:10 PM
05/02/09 06:10 PM
yes
Re: U joint question - swapped center section [Re: Prostock] #305764
05/02/09 06:10 PM
05/02/09 06:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's the same u joint either way.
Don't be the exception.
Re: U joint question - swapped center section [Re: Supercuda] #305765
05/02/09 06:16 PM
05/02/09 06:16 PM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
Maybe I am having a senior moment, but how can replacing the rear ujoint in the driveshaft with this conversion joint work in both center sections, small and large yoke?
Thanks for the replies. I'm going to check with a local driveline shop on Monday.
Re: U joint question - swapped center section [Re: Prostock] #305766
05/02/09 06:21 PM
05/02/09 06:21 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The Joint don't care if the small caps go into the shaft or into the rear end yoke. Or if the large caps do.
Re: U joint question - swapped center section [Re: MoparforLife] #305767
05/02/09 06:26 PM
05/02/09 06:26 PM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
Cool. Thanks for the replies!
Re: U joint question - swapped center section [Re: Prostock] #305768
05/02/09 09:05 PM
05/02/09 09:05 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
You should measure and make sure that you need a 7260/7290 conversion. I could be 7260/1330.
Re: U joint question - swapped center section [Re: BSB67] #305769
05/02/09 09:17 PM
05/02/09 09:17 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
7260/1330 would be a problem because there is no adaptor joint, I just went thru this and had to get a new shaft made with 7290 on the front and 1330 on the rear, there is a 7290/1330 joint but since I was building from scratch I had the 1330 weld yoke installed.
Re: U joint question - swapped center section [Re: MoparJoe] #305770
05/02/09 10:50 PM
05/02/09 10:50 PM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
I measured each today, but I can't remember what they were exactly. I'll measure again tomorrow.
Re: U joint question - swapped center section [Re: Prostock] #305771
05/02/09 11:15 PM
05/02/09 11:15 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
just DONT make the mistake i did... YOU MUST GET THE CORRECT STRAPS for the SMALL u joint the originals [from the large] will work for a while... DAMHIK... i knew i had to do it but just forgot... broke the trans tailshaft clean off..luckily no other damage.. dan
Re: U joint question - swapped center section [Re: 68Fastback] #305772
05/03/09 12:14 AM
05/03/09 12:14 AM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
The place that did the driveshaft installed the joint I think it was a Spicer.
Re: U joint question - swapped center section [Re: ph23vo] #305773
05/03/09 10:34 AM
05/03/09 10:34 AM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
The replacement center section had the straps on it.
I'll measure it today. What is needed, length and width?
Re: U joint question - swapped center section [Re: Prostock] #305774
05/03/09 04:29 PM
05/03/09 04:29 PM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
One is 3 1/4" X 2, the larger is 3 3/4 X 2.
Re: U joint question - swapped center section [Re: Prostock] #305775
05/03/09 10:29 PM
05/03/09 10:29 PM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
Bump. Is the conversion joint the one I need?
Re: U joint question - swapped center section [Re: Prostock] #305776
05/03/09 11:15 PM
05/03/09 11:15 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
REad about half way down on this link it has the numbers that may help.
http://www.moparts.org/Tech/Archive/shaft/5.html
