Re: U joint question - swapped center section
[Re: Prostock]
#305758
05/02/09 05:40 PM
05/02/09 05:40 PM
Posts: 18,157 Mass
DAYCLONA
Mass
No part number off hand, but there is a conversion joint available from CarQuest, and Autozone,....it's a cheapy,...I'd recommend you stop by a driveshaft shop and get the Splicer brand, unless CQ or AZ can get can assure you of the Splicer brand,....I have two cars running the conversion joints,...no problems,......also contact DrDiff here on Moparts, I believe he has conversion joints as well
[Re: 69DartGT]
#305761
05/02/09 05:48 PM
05/02/09 05:48 PM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
Jess if I remember correctly the Dart has a conversion u joint on it?
Yes it does, I noticed that. I had never seen one before so threw me off for a bit.
[Re: Supercuda]
#305765
05/02/09 06:16 PM
05/02/09 06:16 PM
Posts: 12,120 City of Champions
Prostock
City of Champions
The one I took out has a smaller yoke on it than the one I put in. Is that the conversion ujoint for going that way?
It's the same u joint either way.
Maybe I am having a senior moment, but how can replacing the rear ujoint in the driveshaft with this conversion joint work in both center sections, small and large yoke?
Thanks for the replies. I'm going to check with a local driveline shop on Monday.
[Re: BSB67]
#305769
05/02/09 09:17 PM
05/02/09 09:17 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
You should measure and make sure that you need a 7260/7290 conversion. I could be 7260/1330.
7260/1330 would be a problem because there is no adaptor joint, I just went thru this and had to get a new shaft made with 7290 on the front and 1330 on the rear, there is a 7290/1330 joint but since I was building from scratch I had the 1330 weld yoke installed.
[Re: 68Fastback]
#305772
05/03/09 12:14 AM
05/03/09 12:14 AM
Posts: 12,405 Southern, Ca.
69DartGT
moparts member
moparts member
Southern, Ca.
The place that did the driveshaft installed the joint I think it was a Spicer.
[Re: ph23vo]
#305773
05/03/09 10:34 AM
05/03/09 10:34 AM
Prostock
City of Champions
just DONT make the mistake i did... YOU MUST GET THE CORRECT STRAPS for the SMALL u joint the originals [from the large] will work for a while... DAMHIK... i knew i had to do it but just forgot... broke the trans tailshaft clean off..luckily no other damage.. dan
The replacement center section had the straps on it.
I'll measure it today. What is needed, length and width?
