Lower control arm bushings #3044259
05/22/22 10:57 AM
05/22/22 10:57 AM
canal fulton, ohio
2
2ton4door Offline OP
canal fulton, ohio
Hello,
I am trying to replace the lower control arm bushings. The ones I have now are supposedly K791 Moog which is supposed to be the correct ones and the pivot shaft is the same size as the inner sleeve in the bushing. Do I have the wrong ones or am I supposed to drive the inner shaft out with the pivot shaft. Thanks for any help.
Re: Lower control arm bushings [Re: 2ton4door] #3044260
05/22/22 11:04 AM
05/22/22 11:04 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
You have to remove the old bushing inner ring off of pivot shaft.
Press shaft onto new bushing.
Then that assembly into lower arm, using outer rim of bushing.
Do not press in using the pivot shaft
Re: Lower control arm bushings [Re: PhillyRag] #3044262
05/22/22 11:10 AM
05/22/22 11:10 AM
canal fulton, ohio
2
canal fulton, ohio
Thanks I see that now, thank you very much
Re: Lower control arm bushings [Re: 2ton4door] #3044277
05/22/22 11:52 AM
05/22/22 11:52 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
If this is your first time changing those bushings, it would be very helpful to get some experienced help. There are a number of pitfalls that are easy to avoid with a little experience and a press. twocents
Master, again and still
Re: Lower control arm bushings [Re: DaveRS23] #3044315
05/22/22 01:38 PM
05/22/22 01:38 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I found an article in one of the magazines on how to do those and it was literally "a breeze" following the instructions. To remove the bushing from the LCA you weld a large thick washer to the bushing so you have something to press against. To remove the sleeve from the pin you use a cold chisel to pound a couple continuous dents down the length of the sleeve, which expands the sleeve and it easily slips off the pin.
Re: Lower control arm bushings [Re: Stanton] #3044341
05/22/22 03:24 PM
05/22/22 03:24 PM
A727Tflite Offline
A727Tflite  Offline
Find a washer almost as large as the ID of the bushing sleeve.
Slide it in the bore. Then take a chisel and hammer the bushing sleeve in on itself capturing the washer inside the sleeve.
Then press the bushing sleeve out using the washer which is captured inside the sleeve. No welding necessary.
Re: Lower control arm bushings [Re: A727Tflite] #3044348
05/22/22 03:51 PM
05/22/22 03:51 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
iagree No need to weld anything.
Re: Lower control arm bushings [Re: DaveRS23] #3044365
05/22/22 04:54 PM
05/22/22 04:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The welding is a 20 second deal. No marks on the arm from hammer and chisel. Plus the heat shrinks the sleeve making it come out easy.
I've done them both ways. I'd weld it if you have the equipment.
Doug
Re: Lower control arm bushings [Re: dvw] #3044368
05/22/22 05:08 PM
05/22/22 05:08 PM
A727Tflite Offline
A727Tflite  Offline
Doug
By the time you get your welding equipment out i’d have the bushings out.
But I do need to wear my reading glasses to make sure I hit the bushing and not the pivot or my fingers.
Re: Lower control arm bushings [Re: A727Tflite] #3044468
05/22/22 11:05 PM
05/22/22 11:05 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
These are my videos showing how to remove and install the bushings.
https://youtu.be/xYkQSI-2NRw
https://youtu.be/f2Op00pO6Kw
Re: Lower control arm bushings [Re: Jim_Lusk] #3044552
05/23/22 10:38 AM
05/23/22 10:38 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ive always welded a washer inside the sleeve and press it out from the back side
Re: Lower control arm bushings [Re: gtx6970] #3044669
05/23/22 06:24 PM
05/23/22 06:24 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
Certainly nothing wrong with that method...................for those with a welder handy.
Re: Lower control arm bushings [Re: DaveRS23] #3044683
05/23/22 07:16 PM
05/23/22 07:16 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I've used a large pipe tap. Then use a press to push against tap to remove bushing.
Re: Lower control arm bushings [Re: 469runner] #3044752
05/24/22 03:01 AM
05/24/22 03:01 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
There's a tool that wedges and grips the I.D. of the bushing so it can be pulled out, no welding needed. It used to be American Muscle, apparently now Mopar Performance. But that particular tool might be AWOL from the MP kit (?).
02 Front Suspension.L lower control arm17.bushing shell removal..jpg02 Front Suspension.L lower control arm18.bushing shell removal..jpg02 Front Suspension.L lower control arm14.bushing shell removal..JPG02 Front Suspension.L lower control arm15.bushing shell removal..JPG
Re: Lower control arm bushings [Re: kentj340] #3044761
05/24/22 07:23 AM
05/24/22 07:23 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
I've got one of the removal tools. It can be tricking getting it in the bushing shell correctly, but once you get it in there it works great.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
