Re: Lower control arm bushings
[Re: Stanton]
#3044341
05/22/22 03:24 PM
05/22/22 03:24 PM
Posts: 3,076 Michigan
A727Tflite
I found an article in one of the magazines on how to do those and it was literally "a breeze" following the instructions. To remove the bushing from the LCA you weld a large thick washer to the bushing so you have something to press against. To remove the sleeve from the pin you use a cold chisel to pound a couple continuous dents down the length of the sleeve, which expands the sleeve and it easily slips off the pin. Find a washer almost as large as the ID of the bushing sleeve. Slide it in the bore. Then take a chisel and hammer the bushing sleeve in on itself capturing the washer inside the sleeve. Then press the bushing sleeve out using the washer which is captured inside the sleeve. No welding necessary.
[Re: dvw]
#3044368
05/22/22 05:08 PM
05/22/22 05:08 PM
A727Tflite
The welding is a 20 second deal. No marks on the arm from hammer and chisel. Plus the heat shrinks the sleeve making it come out easy. I've done them both ways. I'd weld it if you have the equipment. Doug By the time you get your welding equipment out i’d have the bushings out. But I do need to wear my reading glasses to make sure I hit the bushing and not the pivot or my fingers.
[Re: gtx6970]
#3044669
05/23/22 06:24 PM
05/23/22 06:24 PM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Certainly nothing wrong with that method...................for those with a welder handy.
Master, again and still
[Re: 469runner]
#3044752
05/24/22 03:01 AM
05/24/22 03:01 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
There's a tool that wedges and grips the I.D. of the bushing so it can be pulled out, no welding needed. It used to be American Muscle, apparently now Mopar Performance. But that particular tool might be AWOL from the MP kit (?).
[Re: kentj340]
#3044761
05/24/22 07:23 AM
05/24/22 07:23 AM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
I've got one of the removal tools. It can be tricking getting it in the bushing shell correctly, but once you get it in there it works great.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
