Anybody seen a gear pattern like this? #3037785
04/27/22 09:46 PM
04/27/22 09:46 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I don't do alot of ring and pinion set up. But I've never seen one that clears the entire tooth on drive and coast. Preload is correct. .008" back lash, .033" pinion shim. Original shim was under the pinion head bearing race. It was ".031. It's 9 case 8 3/4. Also odd is that the crush sleeve eliminator came with about .060" worth of shims. It needed .088" to get to 25in/lb of pinion preload. I double checked the pinion races to be set flush. No burrs underneath. This is a new factory 2.76. Timken bearings.
Doug
Re: Anybody seen a gear pattern like this? [Re: dvw] #3037812
04/27/22 11:10 PM
04/27/22 11:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That sure is a strange pattern that I have never seen before. I just wonder how it would sound and it may run hot with that much contact shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Anybody seen a gear pattern like this? [Re: fourgearsavoy] #3037820
04/27/22 11:42 PM
04/27/22 11:42 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
have build 1000s of rear ends in my life never seen one come out like that. So is 489 case 8 3/4 . So it has the big pinion with the large taper crush sleeve .
Re: Anybody seen a gear pattern like this? [Re: VernMotor] #3037821
04/27/22 11:45 PM
04/27/22 11:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never seen that before.
I say run it. Where you going to move it to?
What's the pinion look like?
Re: Anybody seen a gear pattern like this? [Re: dvw] #3037843
04/28/22 12:45 AM
04/28/22 12:45 AM
Boise
Moparteacher Offline
Boise
Looks like the wipe is a hair below the crown and not rolling off the crown, and a hair above the root (root would be bad). It also appears it's not rolling off the toe (which would be OK), but is rolling off the heel (which is OK). Technically I'm not sure the pattern gets any better than that with lots of conatct area and no crown or root issues. Yep, run it.
Re: Anybody seen a gear pattern like this? [Re: dvw] #3037850
04/28/22 01:34 AM
04/28/22 01:34 AM
New or used Ring and Pinion gears?
What brand are they?
Re: Anybody seen a gear pattern like this? [Re: Cab_Burge] #3037867
04/28/22 07:44 AM
04/28/22 07:44 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
It is a 1 7/8" tapered pinion. The is a new factory gear set. Date 0- 25 -73 pn 2070684-2.76 There was no gear in the case when I got it. The gear wasn't in a box either. Both ring and pinion had a "D" painted on them in white.
Doug
Re: Anybody seen a gear pattern like this? [Re: CMcAllister] #3037880
04/28/22 08:28 AM
04/28/22 08:28 AM
an8sec70cuda Offline
iagree thumbs
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Anybody seen a gear pattern like this? [Re: an8sec70cuda] #3037882
04/28/22 08:41 AM
04/28/22 08:41 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The only time I ever had a rear end rebuilt the guy doing it smeared the grease on about 5 teeth, rotated the pinion about one turn and showed me the pattern was correct. In this case I think you've overdone it - turned it so often that the grease has spread out and erased the contact pattern. Wipe it all off and try it again on a small spot with only one rotation.
Re: Anybody seen a gear pattern like this? [Re: dvw] #3037888
04/28/22 08:55 AM
04/28/22 08:55 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have only seen a clean wipe pattern like that on used gears.
Re: Anybody seen a gear pattern like this? [Re: Stanton] #3037900
04/28/22 09:44 AM
04/28/22 09:44 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I agree, to much grease on the gear, just put on the face of tooth, clean and do small area once around, won’t hurt
Re: Anybody seen a gear pattern like this? [Re: cudaman1969] #3037958
04/28/22 12:47 PM
04/28/22 12:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The compound should be used sparingly, not globbed on. However, if there is an area where the gears aren't in contact, the stuff won't be rubbed off. Rotating the assembly around a few times to catch clean teeth on the pinion will make the pattern more distinct.
Compound left on the pinion is also helpful to observe.
Re: Anybody seen a gear pattern like this? [Re: CMcAllister] #3037973
04/28/22 01:18 PM
04/28/22 01:18 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
use less compound and make sure you have a load on it
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Anybody seen a gear pattern like this? [Re: 440lebaron] #3037980
04/28/22 01:58 PM
04/28/22 01:58 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
There was only a light coating on 3 teeth only. The other teeth have a " ghosted" pattern that shows the same image. The ring gear was loaded.
Doug
Re: Anybody seen a gear pattern like this? [Re: dvw] #3038062
04/28/22 09:49 PM
04/28/22 09:49 PM
Fancy Farm Ky
W
wyoming Online content
wyoming  Online Content
W
Fancy Farm Ky
Ive seen that on used gears, but thats it.
