Re: Anybody seen a gear pattern like this?
[Re: VernMotor]
#3037821
04/27/22 11:45 PM
04/27/22 11:45 PM
Posts: 11,586 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Never seen that before.
I say run it. Where you going to move it to?
What's the pinion look like?
[Re: dvw]
#3037850
04/28/22 01:34 AM
04/28/22 01:34 AM
Posts: 43,202 Bend,OR USA
Cab_Burge
New or used Ring and Pinion gears? What brand are they?
[Re: Cab_Burge]
#3037867
04/28/22 07:44 AM
04/28/22 07:44 AM
Posts: 9,843 MI, usa
dvw
MI, usa
It is a 1 7/8" tapered pinion. The is a new factory gear set. Date 0- 25 -73 pn 2070684-2.76 There was no gear in the case when I got it. The gear wasn't in a box either. Both ring and pinion had a "D" painted on them in white. Doug
[Re: CMcAllister]
#3037880
04/28/22 08:28 AM
04/28/22 08:28 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
[Re: Stanton]
#3037900
04/28/22 09:44 AM
04/28/22 09:44 AM
Posts: 8,274 fredericksburg,va
cudaman1969
fredericksburg,va
The only time I ever had a rear end rebuilt the guy doing it smeared the grease on about 5 teeth, rotated the pinion about one turn and showed me the pattern was correct. In this case I think you've overdone it - turned it so often that the grease has spread out and erased the contact pattern. Wipe it all off and try it again on a small spot with only one rotation. I agree, to much grease on the gear, just put on the face of tooth, clean and do small area once around, won’t hurt
[Re: cudaman1969]
#3037958
04/28/22 12:47 PM
04/28/22 12:47 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The compound should be used sparingly, not globbed on. However, if there is an area where the gears aren't in contact, the stuff won't be rubbed off. Rotating the assembly around a few times to catch clean teeth on the pinion will make the pattern more distinct.
Compound left on the pinion is also helpful to observe.
[Re: CMcAllister]
#3037973
04/28/22 01:18 PM
04/28/22 01:18 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
use less compound and make sure you have a load on it
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
