Pilot bearing #3023608
03/13/22 02:33 PM
03/13/22 02:33 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Are all 340 cranks drilled for pilot bearings?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Pilot bearing [Re: 6T9Hemi] #3023631
03/13/22 03:32 PM
03/13/22 03:32 PM
Chicago
PurpleBeeper Offline
Chicago
I'm not sure about small blocks, but big block cranks certainly are not all drilled.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Pilot bearing [Re: 6T9Hemi] #3023675
03/13/22 06:19 PM
03/13/22 06:19 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I think so. I’ve got and had lots of 340 steel cranks over the years and they all had bushing installed even if the were in an auto car.
Re: Pilot bearing [Re: 6T9Hemi] #3023729
03/13/22 09:04 PM
03/13/22 09:04 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Forged cranks probably yes. Cast cranks probably not all
Re: Pilot bearing [Re: PhillyRag] #3023743
03/13/22 09:27 PM
03/13/22 09:27 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Some are drilled undersize and I don’t know if you can still get that bushing . Mopar had a roller bearing and a bushing that fit into the torque converter pilot area of the crankshaft , but I don’t know if it is still available
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Pilot bearing [Re: doctor_mopar] #3023758
03/13/22 09:47 PM
03/13/22 09:47 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I have never seen one not drilled but that does not mean some are not
I have not been able to get the undersized bushing for the unreamed crank for a long time but anyone with a lathe can turn one down. The needle bearing for the converter register is Timken fc69907.
Re: Pilot bearing [Re: 4406bbl] #3023862
03/14/22 09:24 AM
03/14/22 09:24 AM
Findlay
Ramman Offline
Ramman  Offline
Findlay
Some vendors, I believe Dorman for one, used to make a solid bushing with no needle bearings. For switching a automatic non drilled crank over to a manual transmission application. Does anyone know if this bushing is still available? I'd heard rumors of the needles eating into the input shaft of a manual trans. designed to ride on bronze.
Re: Pilot bearing [Re: Ramman] #3023868
03/14/22 10:02 AM
03/14/22 10:02 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Mopar 04338876 ought to be what you are looking for, unless it's been supplanted by the roller version.
