Pilot bearing
#3023608
03/13/22 02:33 PM
03/13/22 02:33 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
Are all 340 cranks drilled for pilot bearings?
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
Re: Pilot bearing
[Re: 6T9Hemi]
#3023631
03/13/22 03:32 PM
03/13/22 03:32 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I'm not sure about small blocks, but big block cranks certainly are not all drilled.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: Pilot bearing
[Re: 6T9Hemi]
#3023675
03/13/22 06:19 PM
03/13/22 06:19 PM
Posts: 6,416 Abilene, Texas
fastmark
Abilene, Texas
Are all 340 cranks drilled for pilot bearings? I think so. I’ve got and had lots of 340 steel cranks over the years and they all had bushing installed even if the were in an auto car.
Re: Pilot bearing
[Re: 6T9Hemi]
#3023729
03/13/22 09:04 PM
03/13/22 09:04 PM
Posts: 1,757 Phila
PhillyRag
Phila
Are all 340 cranks drilled for pilot bearings? Forged cranks probably yes. Cast cranks probably not all
Re: Pilot bearing
[Re: PhillyRag]
#3023743
03/13/22 09:27 PM
03/13/22 09:27 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
Some are drilled undersize and I don’t know if you can still get that bushing . Mopar had a roller bearing and a bushing that fit into the torque converter pilot area of the crankshaft , but I don’t know if it is still available
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Pilot bearing
[Re: Ramman]
#3023868
03/14/22 10:02 AM
03/14/22 10:02 AM
Posts: 6,279 nowhere
Sniper
nowhere
Some vendors, I believe Dorman for one, used to make a solid bushing with no needle bearings. For switching a automatic non drilled crank over to a manual transmission application. Does anyone know if this bushing is still available? I'd heard rumors of the needles eating into the input shaft of a manual trans. designed to ride on bronze. Mopar 04338876 ought to be what you are looking for, unless it's been supplanted by the roller version.
