Old Index vertical mill parts #3022694
03/10/22 05:29 PM
03/10/22 05:29 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’ve got an old Index verticals mill that I need to get up and running. I think I’ve got the three phase conversion figured out bu all I have for tooling it one drill chuck. I was told that it was older brown and sharp taper. Should I look for brown and sharp tooling, buy adapters or find a company that can convert my spindle to the more common R8 taper?
Re: Old Index vertical mill parts [Re: fastmark] #3022715
03/10/22 07:32 PM
03/10/22 07:32 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Interesting, how old is the machine. Explain “got the 3 phase figured out” please
Re: Old Index vertical mill parts [Re: cudaman1969] #3022725
03/10/22 08:55 PM
03/10/22 08:55 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
MSC Industrial may have some B&S stuff. If not, hunt around on line: stuff is out there. Or you can also have someone turn down the shank of an R8 drill chuck to B&S. My father did it for an old mill we used to have before he got a Bridgeport.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Old Index vertical mill parts [Re: fastmark] #3022811
03/11/22 09:03 AM
03/11/22 09:03 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
http://www.vintagemachinery.org/mfgindex/detail.aspx?id=2280&tab=4
notice far right column of potential owners who you might attempt to contact
Look for local auctions of closed factories and/or machine shops.
Take a picture of your mill with you and mill about in the crowd between bidding periods asking for advice and help.
I predict you will be amazed at how knowledgable some of the “pro” buyers will be.
Warning: majority of machinists are cantankerous, quirky, on the verge of crazy.
Re: Old Index vertical mill parts [Re: 360view] #3022830
03/11/22 10:43 AM
03/11/22 10:43 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
[quote Warning: majority of machinists are cantankerous, quirky, on the verge of crazy. [/quote]
iagree
Re: Old Index vertical mill parts [Re: Hugh Jorgan] #3022879
03/11/22 01:05 PM
03/11/22 01:05 PM
moparx Offline
moparx  Offline
iagree [/quote]
how did you guys know i was like that ??????????? frog rant runaway whistling hop panic biggrin
45 years at this craft before retirement, and still practicing today, will do that to a guy ! laugh2
as to the OP, can you post a picture of your drill chuck out of the spindle ?
at one time, i had some B&S colletts floating around here, but i'm not sure what i did with them.
my stuff now is 5-C and a 5-C to R-8 adapter.
beer
Re: Old Index vertical mill parts [Re: cudaman1969] #3022893
03/11/22 01:27 PM
03/11/22 01:27 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I talked to several electric motor gurus and a couple of electricians and everyone either did not know anything about it or knew something about a static converter that used another motor to generate three phase. It was pretty involved and expensive. My car building bud made a belt sander at his shop. He has three phase already but this is a “ ac motor speed control Hybrid Drive”. You get them on eBay and it is great for making speed changes with instead of changing belts. It has single phase input and three phase output.
Re: Old Index vertical mill parts [Re: fastmark] #3022934
03/11/22 02:32 PM
03/11/22 02:32 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What you describe is what I have called a Roto Phase, single phase 220 motor that manufactures the third leg 220. Mine will run 50 HP and those ‘phase converters’ will lose 40% of your power, ok for a 1/2 hp motor, maybe. If you converted over to single get nothing less than 5hp, about the max for single. The rotary ones are expensive, comparable one like mine is $12,000, I paid $250, got it with my 37” wide belt sander. 3 phase motors can be started and run with a made up gizzmo, look it up on u-tube.
Re: Old Index vertical mill parts [Re: fastmark] #3022956
03/11/22 03:56 PM
03/11/22 03:56 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
There are several Brown & Sharp tapers, you need to know which one you have before looking for arbors or adapters.
https://www.starkindustrial.com/brown-and-sharpe-taper-standard
For the phase conversion you might consider a VFD:
https://vfds.com/blog/can-a-vfd-convert-single-phase-power-to-three-phase/
Re: Old Index vertical mill parts [Re: John_Kunkel] #3022972
03/11/22 04:48 PM
03/11/22 04:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Yep just like above. Very simple hookup and cheap
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Old Index vertical mill parts [Re: 360view] #3023052
03/11/22 09:38 PM
03/11/22 09:38 PM
CA
crackedback Offline
crackedback  Offline
CA
Much like here.... LOL
Re: Old Index vertical mill parts [Re: crackedback] #3023383
03/12/22 08:20 PM
03/12/22 08:20 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Yes the VFD is the modern answer. I bought a big Mazak style Chin Hung lathe from the government auction site, I changed the motor from 600v to 208, and then gutted the entire electrical panel on it. The VFD replaces all the speed and reversing contactors and also has an internal brake that stops the lathe instantly. I can also set the speeds better than before. Motor was 550.00, Vfd was 700.00, Total investment was 3250.00 for a really decent machine.
Re: Old Index vertical mill parts [Re: Uberpube] #3023670
03/13/22 05:41 PM
03/13/22 05:41 PM
Rio Linda, CA
Rio Linda, CA
What hp motor and VFD did you use?
Re: Old Index vertical mill parts [Re: Hugh Jorgan] #3023803
03/14/22 12:05 AM
03/14/22 12:05 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
iagree [/quote]
An accurate description of my father grin
Ed
Re: Old Index vertical mill parts [Re: John_Kunkel] #3024708
03/16/22 09:17 PM
03/16/22 09:17 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
- used a lower end lenze 15hp drive with a generic 7.6 hp motor that I machined down on small lathe to make the pulley fit.
-'ve done a pile of projects with single phase to three phase conversions, fans pumps,augers,etc and I found that to make it work, the vfd has to be rated for double the size of the motor nameplate to make last.
Another one I did in my own shop that was neat, its a jet drillpress I was given. It had a good quality quill and chuck, but a dinky motor that would stall on larger bits. I took a surplus 3 phase motor I had from an air conditioner, 1.0 hp and put it on a vfd.now the cool thing about the smaller vfd's is that you power them with 115v single phase and make 208v 3phase. On the drill press, now I have infinite speed control, soft start, and reverse for LH drill bits.
The lathe electrical is gutted, the vfd replaces all the contactos.
Re: Old Index vertical mill parts [Re: fastmark] #3025202
03/18/22 03:44 PM
03/18/22 03:44 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
A big drawback to the VFD is that it will only drive one motor at a time. If you have any power feeds they will need a separate power source.
It wants to start and stop the motor. If you want to reverse the motor (like power tapping) you have to do it through the VFD.
I ran my machines on VFDs for years. A while back I bought an American Rotary phase converter and my world has been a much happier place.
- Stu Harmon
Re: Old Index vertical mill parts [Re: fastmark] #3025219
03/18/22 05:09 PM
03/18/22 05:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I had an old Wells Index milling machine, just run a phase convertor, cheap@ $3-400 bucks, simple hook up, zero issues....arbors/collets can be had on Ebay cheaper than going R8....
Re: Old Index vertical mill parts [Re: feets] #3025639
03/20/22 07:36 AM
03/20/22 07:36 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks for all the feedback guys. I guess I don’t have the three phase figured out, then. The guy that gave me the info on the VFD has one on shelf sander that he made. It works great on his but he uses it only as a speed control on his sander. I have two motors. One is on the spindle and one on the table feed. So I guess I can’t use the VFD according to feets. I’ll check American rotary phase converter. My spindle motor is only 1.5 up. As far as the collet. I have one tool that came with it. It is a drill Chuck. I’ll post a picture of it and the spindle. It looks to be just a 1/2” straight shaft. I’m out of my element her for sure. Any help is appreciated.
Re: Old Index vertical mill parts [Re: fastmark] #3025686
03/20/22 11:12 AM
03/20/22 11:12 AM
moparx Offline
moparx  Offline
looks like the collet you have for the drill chuck is 1/2". [or what the shaft size of the drill chuck is]
unscrew the retainer nut from the spindle shaft and the collet will be exposed. it may need a small tap to get it out of the spindle, but when it comes out, that is the style of collets you need to look for.
post a picture of it. i "may" have some of that style still around, and if i do, i'll give 'em to ya.
it's been a long time since i have seen them, and they may have been long gone, but i can at least look.
beer
Re: Old Index vertical mill parts [Re: fastmark] #3025690
03/20/22 11:25 AM
03/20/22 11:25 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The tool you use to mount the drill chuck looks like a universal Z collet holder. If so, ZZ collects can be found in almost any size you want. My Tree 2UVR uses those collects in a quick change system. Good stuff. I had a holder similar to yours in my old Gorton O-16a.
Chances are good that you've got a 30 B&S spindle. Those used to be fairly common on mid size mills back in the day.
- Stu Harmon
