Re: Old Index vertical mill parts
[Re: cudaman1969]
#3022725
03/10/22 08:55 PM
03/10/22 08:55 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
MSC Industrial may have some B&S stuff. If not, hunt around on line: stuff is out there. Or you can also have someone turn down the shank of an R8 drill chuck to B&S. My father did it for an old mill we used to have before he got a Bridgeport.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: fastmark]
#3022811
03/11/22 09:03 AM
03/11/22 09:03 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
http://www.vintagemachinery.org/mfgindex/detail.aspx?id=2280&tab=4notice far right column of potential owners who you might attempt to contact Look for local auctions of closed factories and/or machine shops. Take a picture of your mill with you and mill about in the crowd between bidding periods asking for advice and help. I predict you will be amazed at how knowledgable some of the “pro” buyers will be. Warning: majority of machinists are cantankerous, quirky, on the verge of crazy.
[Re: cudaman1969]
#3022893
03/11/22 01:27 PM
03/11/22 01:27 PM
Posts: 6,418 Abilene, Texas
fastmark
Abilene, Texas
Interesting, how old is the machine. Explain “got the 3 phase figured out” please I talked to several electric motor gurus and a couple of electricians and everyone either did not know anything about it or knew something about a static converter that used another motor to generate three phase. It was pretty involved and expensive. My car building bud made a belt sander at his shop. He has three phase already but this is a “ ac motor speed control Hybrid Drive”. You get them on eBay and it is great for making speed changes with instead of changing belts. It has single phase input and three phase output.
[Re: fastmark]
#3022934
03/11/22 02:32 PM
03/11/22 02:32 PM
Posts: 8,294 fredericksburg,va
cudaman1969
fredericksburg,va
Interesting, how old is the machine. Explain “got the 3 phase figured out” please I talked to several electric motor gurus and a couple of electricians and everyone either did not know anything about it or knew something about a static converter that used another motor to generate three phase. It was pretty involved and expensive. My car building bud made a belt sander at his shop. He has three phase already but this is a “ ac motor speed control Hybrid Drive”. You get them on eBay and it is great for making speed changes with instead of changing belts. It has single phase input and three phase output. What you describe is what I have called a Roto Phase, single phase 220 motor that manufactures the third leg 220. Mine will run 50 HP and those ‘phase converters’ will lose 40% of your power, ok for a 1/2 hp motor, maybe. If you converted over to single get nothing less than 5hp, about the max for single. The rotary ones are expensive, comparable one like mine is $12,000, I paid $250, got it with my 37” wide belt sander. 3 phase motors can be started and run with a made up gizzmo, look it up on u-tube.
[Re: John_Kunkel]
#3022972
03/11/22 04:48 PM
03/11/22 04:48 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yep just like above. Very simple hookup and cheap
[Re: 360view]
#3023052
03/11/22 09:38 PM
03/11/22 09:38 PM
Posts: 2,079 CA
crackedback
CA
Much like here.... LOL
[Re: Uberpube]
#3023670
03/13/22 05:41 PM
03/13/22 05:41 PM
Posts: 25,887 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What hp motor and VFD did you use?
[Re: Hugh Jorgan]
#3023803
03/14/22 12:05 AM
03/14/22 12:05 AM
EWJ
Back in NJ....
[quote Warning: majority of machinists are cantankerous, quirky, on the verge of crazy. [/quote] An accurate description of my father
[Re: John_Kunkel]
#3024708
03/16/22 09:17 PM
03/16/22 09:17 PM
Posts: 712 Southern Alberta
Uberpube
Southern Alberta
What hp motor and VFD did you use? - used a lower end lenze 15hp drive with a generic 7.6 hp motor that I machined down on small lathe to make the pulley fit. -'ve done a pile of projects with single phase to three phase conversions, fans pumps,augers,etc and I found that to make it work, the vfd has to be rated for double the size of the motor nameplate to make last. Another one I did in my own shop that was neat, its a jet drillpress I was given. It had a good quality quill and chuck, but a dinky motor that would stall on larger bits. I took a surplus 3 phase motor I had from an air conditioner, 1.0 hp and put it on a vfd.now the cool thing about the smaller vfd's is that you power them with 115v single phase and make 208v 3phase. On the drill press, now I have infinite speed control, soft start, and reverse for LH drill bits. The lathe electrical is gutted, the vfd replaces all the contactos.
[Re: fastmark]
#3025202
03/18/22 03:44 PM
03/18/22 03:44 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
A big drawback to the VFD is that it will only drive one motor at a time. If you have any power feeds they will need a separate power source. It wants to start and stop the motor. If you want to reverse the motor (like power tapping) you have to do it through the VFD.
I ran my machines on VFDs for years. A while back I bought an American Rotary phase converter and my world has been a much happier place.
[Re: fastmark]
#3025219
03/18/22 05:09 PM
03/18/22 05:09 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I’ve got an old Index verticals mill that I need to get up and running. I think I’ve got the three phase conversion figured out bu all I have for tooling it one drill chuck. I was told that it was older brown and sharp taper. Should I look for brown and sharp tooling, buy adapters or find a company that can convert my spindle to the more common R8 taper? I had an old Wells Index milling machine, just run a phase convertor, cheap@ $3-400 bucks, simple hook up, zero issues....arbors/collets can be had on Ebay cheaper than going R8....
[Re: fastmark]
#3025686
03/20/22 11:12 AM
03/20/22 11:12 AM
Posts: 19,485 north of coder
moparx
looks like the collet you have for the drill chuck is 1/2". [or what the shaft size of the drill chuck is] unscrew the retainer nut from the spindle shaft and the collet will be exposed. it may need a small tap to get it out of the spindle, but when it comes out, that is the style of collets you need to look for. post a picture of it. i "may" have some of that style still around, and if i do, i'll give 'em to ya. it's been a long time since i have seen them, and they may have been long gone, but i can at least look.
[Re: fastmark]
#3025690
03/20/22 11:25 AM
03/20/22 11:25 AM
feets
Senior Management
Senior Management
Irving, TX
The tool you use to mount the drill chuck looks like a universal Z collet holder. If so, ZZ collects can be found in almost any size you want. My Tree 2UVR uses those collects in a quick change system. Good stuff. I had a holder similar to yours in my old Gorton O-16a.
Chances are good that you've got a 30 B&S spindle. Those used to be fairly common on mid size mills back in the day.
