spring for kickdown linkage #302153
04/28/09 05:38 PM
04/28/09 05:38 PM
Michigan Troll
blk00rt Offline OP
blk00rt  Offline OP
Michigan Troll
I know where i can find the spring for the carb, but where can I find the spring that attaches to the bell housing on the transmission to the kick down arm on the valve body. This is for a 904 transmission if that makes a difference.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: spring for kickdown linkage [Re: blk00rt] #302154
04/28/09 05:46 PM
04/28/09 05:46 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
mine's an internal spring? The arm returns itself.
Re: spring for kickdown linkage [Re: blk00rt] #302155
04/28/09 06:03 PM
04/28/09 06:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You can still get repos, Try Bill at Hiteh Auto GTX6970 If not then anyone who sells repo stuff will have them.
Re: spring for kickdown linkage [Re: blk00rt] #302156
04/28/09 07:56 PM
04/28/09 07:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is no linkage return spring at the transmission end, the linkage return spring is at the carburetor end.
Re: spring for kickdown linkage [Re: John_Kunkel] #302157
04/28/09 08:28 PM
04/28/09 08:28 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
some diagragms showed a spring down there but they are incorrect...spring is on top by the carb linkage
Re: spring for kickdown linkage [Re: blk00rt] #302158
04/28/09 08:32 PM
04/28/09 08:32 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
the only kickdown springs used that I'm aware of
Re: spring for kickdown linkage [Re: AARCONV] #302159
04/29/09 05:34 PM
04/29/09 05:34 PM
Michigan Troll
blk00rt Offline OP
blk00rt  Offline OP
Michigan Troll
thanks everyone, I am getting close to starting it and thought there was a spring down there too.
Rob Dunn
1976 Dart Sport 360
2009 Jeep Patriot
Re: spring for kickdown linkage [Re: blk00rt] #302160
04/29/09 08:19 PM
04/29/09 08:19 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Throttle pressure linkage....not kickdown linkage
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: spring for kickdown linkage [Re: 69L78Nova] #302161
05/04/09 03:41 AM
05/04/09 03:41 AM
Missouri
NFURY8 Offline
super street
NFURY8  Offline
super street
Missouri
I pulled a 46RE out of a 2001 van this weekend, it had a spring on the pressure lever that went up to a small bracket where the shifter pivot rod bolts to the transmission. I looked at an old 727 in the garage and noticed the lever had the same hole in it that the spring was attached to.
For what ever it is worth.
