Re: Automatic Trans Holding Fixture
[Re: B1MAXX]
#3018600
02/24/22 06:43 PM
02/24/22 06:43 PM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
Just use a common 2 wheel dolly. Put bellhousing end up and tailshaft on the floorplate. Use a ratchet strap just above the pan surface at back of bell to hold it to the dolly. Done 100+ this way. Use a wheelbarrow and you don't even need to mess with the ratchet strap I'm not knocking it one bit but the first thing that came into my head was the intro to dueling banjos. You're not the first person to say that. It worked though.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: POZEST]
#3018797
02/25/22 12:32 PM
02/25/22 12:32 PM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I just use my Blue Point bench mule.
Torqueflites get one leg bolted to the front tab, use a 2 3/4" spacer with a long bolt on the rear tab. If the tabs are gone, I use the bellhousing.
OE Powerglides I use a couple bolts on the pan flange.
[Re: CMcAllister]
#3019532
02/27/22 09:48 PM
02/27/22 09:48 PM
Posts: 554 Kentucky
clovis
Kentucky
Special thanks to B1MAXX, for the extra photos. It enable to me to create one from an engine stand with very little work-$8 worth of the angle iron and I was in business. It works out good as I can drop it onto the middle leg to pre-load the output for checking final clearance. That’s my chief mechanic, at work there with the converter. My dad will turn 80 next birthday, and I still have to fight him to get to the wrenches first.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
