Re: Automatic Trans Holding Fixture
[Re: MoParFish]
#2423678
12/25/17 05:57 PM
12/25/17 05:57 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Nuttin' fancy here. Hole drilled in edge of bench with a screwdriver dropped thru bell hole. Has worked ok for as many as I mess with but, might make something better next time around. Is the screw driver from Harbor Freight?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Bad340fish]
#2423823
12/26/17 02:18 AM
12/26/17 02:18 AM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Blue Point bench mule I bought from Snappy years ago. Has had transmissions and rears on it over the years. It's paid for itself a few times over.
[Re: cudaman1969]
#2423844
12/26/17 10:19 AM
12/26/17 10:19 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Once it's ready for the guts, Nothing more than a 15? gallon drum (parts cleaner drum) goes together better being vertical. Lol...I thought I was the only one...and I wasn't going to admit it...I don't do them often but I use one for disassembly and the reassembly, I do like the engine stand adapter idea though...right after I finish my engine run in stand I may build one of those...ha...who am I kidding, I can't seem to keep other people's projects out of my shop...
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: longram60]
#2424198
12/27/17 12:34 AM
12/27/17 12:34 AM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
I use a similar set-up with my engine stand, bur with a C shaped angle iron fixture bolted to the face of the tranny (I'll post a pic when I get home) I made up some arms to bolt to an engine stand and the tabs on the torqueflite case. Took about an hour to make them out of scrap I had in the shop. Works great. I had some 2x2 tubing and 1/2 x 1 bar stock. I cut four pieces of bar stock to 4 1/2 inch long, drilled a 7/16 hole in one end of each close enough to the end to seat properly on the transmission tabs, and welded them onto the 2x2 x 8 inch long pieces of tubing, with the holes extending out on opposite ends. That allows a lot of adjustability for mounting the trans case. Picture of mine:
1979 AMC Spirit, NHRA Q/SA
[Re: B1MAXX]
#3017943
02/23/22 08:59 AM
02/23/22 08:59 AM
Posts: 4,075 Mo.
racerx
Mo.
Just a couple of gusseted angle brackets, did about a dozen tranny's over 20+ years. I know that some cut the lugs off. I like this setup nice and simple B1maxx was this something you fab. up?
[Re: B1MAXX]
#3017980
02/23/22 11:45 AM
02/23/22 11:45 AM
Posts: 31,075 Oregon
AndyF
With the pivot point so far off center of mass, I would think that could make rotation take a little more effort, or get away from you if your not careful. The pivot is in the center, you just can't see it since it is on the other side.
[Re: Bad340fish]
#3017998
02/23/22 12:41 PM
02/23/22 12:41 PM
Posts: 10,046 MN
JERICOGTX
MN
What is everyone using to hold an automatic transmission while working on them? Trans rebuilding is something I haven't done yet and I think I need to start. Something cheap but safe would be ideal. Also any tool suggestions would be great. Thanks for any input. Hey Clark, here is the proper "Fixture" for a 727. LOL!!!
69 GTX
68 Road Runner
[Re: AndyF]
#3018001
02/23/22 12:43 PM
02/23/22 12:43 PM
Posts: 2,007 Apollo, PA.
B1MAXX
Apollo, PA.
With the pivot point so far off center of mass, I would think that could make rotation take a little more effort, or get away from you if your not careful. The pivot is in the center, you just can't see it since it is on the other side. OK thanks for explaining.
[Re: racerx]
#3018004
02/23/22 12:45 PM
02/23/22 12:45 PM
B1MAXX
Apollo, PA.
Just a couple of gusseted angle brackets, did about a dozen tranny's over 20+ years. I know that some cut the lugs off. I like this setup nice and simple B1maxx was this something you fab. up? Yes just cut up some angle I had around., and some gussets.
[Re: hemi-itis]
#3018005
02/23/22 12:45 PM
02/23/22 12:45 PM
Posts: 8,344 fredericksburg,va
cudaman1969
fredericksburg,va
I'm a simple guy and luckily don't deal with it to often Your bench looks like mine right now, Van overdrive trans. Been thinking of making one to fit on an engine stand sideways, able to spin it and when done set it on the trans jack (they are heavier now a days) Just like BMaxx nice!
