D/W Series steering column interchange question #3014844
02/12/22 10:11 PM
02/12/22 10:11 PM
Bennett, Colorado
Charger69RT8 Offline OP
Bennett, Colorado
How did these change through the years? Will a mid 80's tilt column fit in a '76? Bolt in? Fits with modifications? If anybody has first hand experience, that would be great to hear about. TIA.
2012 Challenger SRT
2012 Charger SXT AWD
69 Charger R/T
78 Chrysler New Yorker 440CI
89 Dodge Daytona ES 2.5L Turbo
99 Ram 2500 4X4 5.9L6
Re: D/W Series steering column interchange question [Re: Charger69RT8] #3014852
02/12/22 10:43 PM
02/12/22 10:43 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
anything can be made to work on anything. lots of different wiring between the 2. my 76 has a tilt column but is totally different than any of my other 81-93 tilts. the usual break down is 72-75, 76-80,81-87, 88-93. i was in touch with a giy on facebook named mike slay. he buys, sells, trades used and nos stuff. he told me he has/had a tilt for a 76 like mine for 250.00. that is cheap i thing, but being retired and on ss, it is more than i can spend.
Re: D/W Series steering column interchange question [Re: Charger69RT8] #3014856
02/12/22 10:52 PM
02/12/22 10:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
No. Not without a lot of work. When you say mid 80's what year exactly? 87 and newer are very different.
Re: D/W Series steering column interchange question [Re: NITROUSN] #3014877
02/13/22 12:42 AM
02/13/22 12:42 AM
Bennett, Colorado
Bennett, Colorado
trw1982 That is good info. Thanks for the response.
NITROUSN Found a seller of one who only list it as a mid 80's. Picture from the ad below will maybe help identify it.
2012 Challenger SRT
69 Charger R/T
Re: D/W Series steering column interchange question [Re: Charger69RT8] #3014950
02/13/22 10:38 AM
02/13/22 10:38 AM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
i have 2 of those. i got 1 out of and 86 and other out of 85. i got mine from a u pull it yards. 35.00 for 1 and 27.50 for the other. plus my 10% veterans discount. try the name i mentioned. he will treat you right. good guy.
Re: D/W Series steering column interchange question [Re: Charger69RT8] #3014962
02/13/22 11:15 AM
02/13/22 11:15 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Ok that could be used. Now what year are you going to put it in.
Re: D/W Series steering column interchange question [Re: NITROUSN] #3014966
02/13/22 11:18 AM
02/13/22 11:18 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I see you referenced it going into a 76. 1 problem will be no shift indicator. 2-you will need to source a intermediate shaft from the column to the gear box. Then you have to look at the wiring?
Re: D/W Series steering column interchange question [Re: NITROUSN] #3015538
02/14/22 10:20 PM
02/14/22 10:20 PM
Bennett, Colorado
Bennett, Colorado
I don't really do facebook so I have no idea how I would find the gentlemen you mention trw1982. However, NITROUSN your points are noted. Shift indicator is not an issue. Manual trans in my '76. In fact it is a new toy I just picked up. It is a put together rig from a W100 and a D100 both original /6 with the manual hump. So it has a muddy pedigree, but has good bones. The '78 long bed AdventurerSE I had from 1980 until 1997 had a tilt in it. This one has had a 318 put in it with an A833 OD and floor shift. I have numerous plans for it, but fixing the minor issues and enjoying it for now is what is on the immediate list.
2012 Challenger SRT
69 Charger R/T
Re: D/W Series steering column interchange question [Re: Charger69RT8] #3015550
02/14/22 10:53 PM
02/14/22 10:53 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
go to face book and then go to the page that you type in a name- type in mike slay. his name will come up. contact thru face book or i think i wave a card in garage. will try to get you a pic tonite.
Re: D/W Series steering column interchange question [Re: trw1982] #3015555
02/14/22 11:02 PM
02/14/22 11:02 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
here is a pic of his business card.
Re: D/W Series steering column interchange question [Re: trw1982] #3016201
02/17/22 01:39 AM
02/17/22 01:39 AM
Bennett, Colorado
Bennett, Colorado
Thank you for that business card. I tried the Facebook thing, but there were numerous Mike Slay listings.
2012 Challenger SRT
69 Charger R/T
Re: D/W Series steering column interchange question [Re: Charger69RT8] #3016317
02/17/22 02:50 PM
02/17/22 02:50 PM
Paducah, KY USA Earth
jcruse64 Offline
jcruse64  Offline
Call that number or use that email address. Mike usually is pretty responsive, unless he's on the road picking new parts or delivering. I've bought a few things from him for my '73 truck, and always had good luck with him.
