D/W Series steering column interchange question
#3014844
02/12/22 10:11 PM
02/12/22 10:11 PM
Posts: 283 Bennett, Colorado
Charger69RT8
Bennett, Colorado
How did these change through the years? Will a mid 80's tilt column fit in a '76? Bolt in? Fits with modifications? If anybody has first hand experience, that would be great to hear about. TIA.
2012 Challenger SRT 2012 Charger SXT AWD 69 Charger R/T 78 Chrysler New Yorker 440CI 89 Dodge Daytona ES 2.5L Turbo 99 Ram 2500 4X4 5.9L6
Re: D/W Series steering column interchange question
[Re: Charger69RT8]
#3014856
02/12/22 10:52 PM
02/12/22 10:52 PM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
How did these change through the years? Will a mid 80's tilt column fit in a '76? Bolt in? Fits with modifications? If anybody has first hand experience, that would be great to hear about. TIA. No. Not without a lot of work. When you say mid 80's what year exactly? 87 and newer are very different.
[Re: NITROUSN]
#3014877
02/13/22 12:42 AM
02/13/22 12:42 AM
Charger69RT8
Bennett, Colorado
trw1982 That is good info. Thanks for the response.
NITROUSN Found a seller of one who only list it as a mid 80's. Picture from the ad below will maybe help identify it.
[Re: Charger69RT8]
#3014962
02/13/22 11:15 AM
02/13/22 11:15 AM
NITROUSN
NITROUSN Found a seller of one who only list it as a mid 80's. Picture from the ad below will maybe help identify it. Ok that could be used. Now what year are you going to put it in.
[Re: NITROUSN]
#3015538
02/14/22 10:20 PM
02/14/22 10:20 PM
Charger69RT8
Bennett, Colorado
I don't really do facebook so I have no idea how I would find the gentlemen you mention trw1982. However, NITROUSN your points are noted. Shift indicator is not an issue. Manual trans in my '76. In fact it is a new toy I just picked up. It is a put together rig from a W100 and a D100 both original /6 with the manual hump. So it has a muddy pedigree, but has good bones. The '78 long bed AdventurerSE I had from 1980 until 1997 had a tilt in it. This one has had a 318 put in it with an A833 OD and floor shift. I have numerous plans for it, but fixing the minor issues and enjoying it for now is what is on the immediate list.
[Re: trw1982]
#3016201
02/17/22 01:39 AM
02/17/22 01:39 AM
Charger69RT8
Bennett, Colorado
Thank you for that business card. I tried the Facebook thing, but there were numerous Mike Slay listings.
