NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS #299614
04/25/09 11:39 PM
04/25/09 11:39 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
I ran the Super Bee at Maple Grove today with the new power plant put together by Dwayne Porter (fast68plymouth)for the F.A.S.T racing series. Based on a 383 platform for the car, Dwayne built a low deck motor that gave me a new personal best with the car... 12.07 @ 116.37 MPH in near 90 degree heat . On that run the 60' was 1.938. The new build is very docile at low speeds until you put your foot into it . Thanks Dwayne for all your efforts on the project. I am sure an 11 second run is in my future just as you planned.
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: chagjr] #299615
04/26/09 12:48 AM
04/26/09 12:48 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Harry , 383 or 400 block ?
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: JohnRR] #299616
04/26/09 05:59 AM
04/26/09 05:59 AM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Way to go Harry!
Your in good hands with Dwayne
Ed
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: XXHEMI] #299617
04/26/09 07:51 AM
04/26/09 07:51 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Congrats Harry!!
That'll be an 11 second ride next time out!
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: CJK440] #299618
04/26/09 07:59 AM
04/26/09 07:59 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Wow, very nice !
Dwayne sure has a good handle on those FAST engine combos
Any pics of the car ?
Ron
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: XXHEMI] #299619
04/26/09 08:04 AM
04/26/09 08:04 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Congrats
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: chagjr] #299620
04/26/09 10:03 AM
04/26/09 10:03 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Very impressive!
Can you tell us more about the car/engine/drive train? Is that a "301" intake and what modifications were done to it? What does the car weigh? Any pics?
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: BSB67] #299621
04/26/09 10:10 AM
04/26/09 10:10 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
do you run the larger 440 AVS, at the time I was invoilved with FAST I recall there was some "Grey Area" regarding whether the carb actually required the OEM casting number or if it only needed to look visually correct and functionally identical (IE, you couldn't swap a Vac sec for a Double pumper, etc) the 340/383 AVS is a good 75-100cfm smaller than the 440, it was the first swap (along with the old MP "jetting tips" we used to make way back when
I had a "magic" 69 440 AVS that ran within about .02 of a 750 double pumper on any motor I ran it on...wish I still had that one.
WIZE
In Car:
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: Streetwize] #299622
04/26/09 10:27 AM
04/26/09 10:27 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Your Bee is really buzzin' Harry. Not sure you know but I really root for the underdog.Dwayne did right by you,but that is how he is.Congrats it'll go better
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: scatpacktom] #299623
04/26/09 03:34 PM
04/26/09 03:34 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
With that MPH it shows you have the power for a 11.70 or there abouts.
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: chagjr] #299624
04/26/09 03:38 PM
04/26/09 03:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: BradH] #299625
04/26/09 04:21 PM
04/26/09 04:21 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Nice job Harry..
i am rooting for you to be the first low deck 4V into the 11's. I know you can do it ...
MB
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: HPMike] #299626
04/26/09 07:57 PM
04/26/09 07:57 PM
N of Detroit
DaveDudek Offline
DaveDudek  Offline
N of Detroit
Congrats Harry! Your right, it was HOT and your car ran well. 11`s will be no problem at all..
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: chagjr] #299627
04/27/09 08:27 AM
04/27/09 08:27 AM
Bristol, CT
RalphsRapidTrnst Offline
Bristol, CT
Congrats Harry and Dwayne
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: JohnRR] #299628
04/28/09 09:18 PM
04/28/09 09:18 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Harry , 383 o r 400 block ?
The build is a 400 block with a 4.25 stroke crank
(511 CUBES)... PRH F.A.S.T 906 heads, solid roller camshaft.
Harry
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: chagjr] #299629
11/01/09 11:00 PM
11/01/09 11:00 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
I finished up the season at VMP... I got the Super Bee into the elevens finally.
11.83 @ 117.44 MPH / 1.92 60ft
I plan on running this car next year hoping to improve on the 60 ft. with the bias ply tires. Wish me luck.
I wanted to thank every one again who helped.
R&D- Porter Racing heads
Machine work- Dale Spooner, Danville VA
Heads- Porter racing heads
Assembly/dyno/tuning- Porter Racing heads
Transmission-ATI
Converter-ATI (Specially built for the FAST class)
Drive Shaft- Drive-Line Specialist, Newington, VA
Rearend- Gary,at the college
Thanks Dwayne, This Car really boogies
Harry
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: chagjr] #299630
11/01/09 11:46 PM
11/01/09 11:46 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Congrats Harry and Good Luck next year
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: scatpacktom] #299631
11/01/09 11:55 PM
11/01/09 11:55 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
Sounds like a GREAT combo!!
I wanna do that SO bad!!
Congrats!
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: scatpacktom] #299632
11/02/09 12:20 AM
11/02/09 12:20 AM
WA 98043
thecarfarmer Offline
WA 98043
I guess you could say Mr. Porter is just a tad crafty with those F.A.S.T. combos.
Congrats on 11's in a B-motor B-body!
BTW, I'm kinda' interested in some of how those suspensions manage to hook up on teeny-tiny tires.
If y'all can do it, there may be hope for me keeping the 235/75/$15s on my pickup.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS [Re: thecarfarmer] #299633
11/02/09 05:25 PM
11/02/09 05:25 PM
JohnRR Offline
JohnRR  Offline
-Bill
Nice work Harry
Bill , there is a huge difference between those street RADIALS and the repop BIAS PLYs.
Good luck ...
