NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS
#299614
04/25/09 11:39 PM
04/25/09 11:39 PM
Posts: 236 Richmond , Virginia
chagjr
Richmond , Virginia
I ran the Super Bee at Maple Grove today with the new power plant put together by Dwayne Porter (fast68plymouth)for the F.A.S.T racing series. Based on a 383 platform for the car, Dwayne built a low deck motor that gave me a new personal best with the car... 12.07 @ 116.37 MPH in near 90 degree heat . On that run the 60' was 1.938. The new build is very docile at low speeds until you put your foot into it . Thanks Dwayne for all your efforts on the project. I am sure an 11 second run is in my future just as you planned.
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: NEW F.A.S.T LOW DECK FROM PORTER RACING HEADS
[Re: XXHEMI]
#299617
04/26/09 07:51 AM
04/26/09 07:51 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Congrats Harry!!
That'll be an 11 second ride next time out!
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#299618
04/26/09 07:59 AM
04/26/09 07:59 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Wow, very nice ! Dwayne sure has a good handle on those FAST engine combos Any pics of the car ? Ron
[Re: BSB67]
#299621
04/26/09 10:10 AM
04/26/09 10:10 AM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
do you run the larger 440 AVS, at the time I was invoilved with FAST I recall there was some "Grey Area" regarding whether the carb actually required the OEM casting number or if it only needed to look visually correct and functionally identical (IE, you couldn't swap a Vac sec for a Double pumper, etc) the 340/383 AVS is a good 75-100cfm smaller than the 440, it was the first swap (along with the old MP "jetting tips" we used to make way back when I had a "magic" 69 440 AVS that ran within about .02 of a 750 double pumper on any motor I ran it on...wish I still had that one.
[Re: BradH]
#299625
04/26/09 04:21 PM
04/26/09 04:21 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Nice job Harry.. i am rooting for you to be the first low deck 4V into the 11's. I know you can do it ... MB
[Re: HPMike]
#299626
04/26/09 07:57 PM
04/26/09 07:57 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Congrats Harry! Your right, it was HOT and your car ran well. 11`s will be no problem at all..
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: chagjr]
#299629
11/01/09 11:00 PM
11/01/09 11:00 PM
chagjr
Richmond , Virginia
I finished up the season at VMP... I got the Super Bee into the elevens finally. 11.83 @ 117.44 MPH / 1.92 60ft I plan on running this car next year hoping to improve on the 60 ft. with the bias ply tires. Wish me luck. I wanted to thank every one again who helped. R&D- Porter Racing heads Machine work- Dale Spooner, Danville VA Heads- Porter racing heads Assembly/dyno/tuning- Porter Racing heads Transmission-ATI Converter-ATI (Specially built for the FAST class) Drive Shaft- Drive-Line Specialist, Newington, VA Rearend- Gary,at the college Thanks Dwayne, This Car really boogies
Harry
[Re: scatpacktom]
#299631
11/01/09 11:55 PM
11/01/09 11:55 PM
Posts: 7,497 Austin, TX
HemiDave
Austin, TX
Sounds like a GREAT combo!! I wanna do that SO bad!! Congrats! Dave
[Re: scatpacktom]
#299632
11/02/09 12:20 AM
11/02/09 12:20 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I guess you could say Mr. Porter is just a tad crafty with those F.A.S.T. combos. Congrats on 11's in a B-motor B-body! BTW, I'm kinda' interested in some of how those suspensions manage to hook up on teeny-tiny tires. If y'all can do it, there may be hope for me keeping the 235/75/$15s on my pickup. -Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: thecarfarmer]
#299633
11/02/09 05:25 PM
11/02/09 05:25 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
-Bill
Nice work Harry
Bill , there is a huge difference between those street RADIALS and the repop BIAS PLYs.
Good luck ...
