Denso Alternator terminals #2992692
12/06/21 09:22 PM
12/06/21 09:22 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Doing an upgrade to a Denso alternator that requires the pictured plug for the V regulator. I have the plug but it's the pigtail version requiring butt splice and go which I HATE flame
What should be fairly simple has consumed quite a but of time trying to find the required terminals so I can wire it in without butt splicing. Someone has to know the correct terminal and hopefully a source.
In addition any confirmation on dismantling the connector to get the terminals out would also be helpful. I THINK I have that part under control BUT confirmation would be nice
Any help is greatly appreciated wink
Re: Denso Alternator terminals [Re: TJP] #2992744
12/06/21 11:04 PM
12/06/21 11:04 PM
AndyF Offline
AndyF  Offline
Looks like a Metripack connector to me but you'll have to take it apart to know for sure.
Re: Denso Alternator terminals [Re: TJP] #2992773
12/07/21 12:22 AM
12/07/21 12:22 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
With a sm pick remove the while plastic and you should see a little tab to push down and remove wire.
Re: Denso Alternator terminals [Re: AndyF] #2992835
12/07/21 11:11 AM
12/07/21 11:11 AM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
That would be nice as I have those on hand smile I'll get it apart and be back with a pic if they are not wink beer
Re: Denso Alternator terminals [Re: TJP] #2993057
12/07/21 10:03 PM
12/07/21 10:03 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
The metri=packs i have are the smaller 150 series frown So I'm thinking maybe I need the 280 series ? here's a couple of pic's if anyone can confirm. The retainer flag appears a bit different ? I hate this as it is very frustrating trying to find what should be simple ARRRGGGGHHHH
Re: Denso Alternator terminals [Re: TJP] #2993075
12/07/21 10:47 PM
12/07/21 10:47 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I always strip the harnesses off of the junk yard engines we get at work. I could probably get you the Denso connector with about 3 feet of wire attached to it shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Denso Alternator terminals [Re: TJP] #2993076
12/07/21 10:48 PM
12/07/21 10:48 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I would try mouser or digikey to find that. NEIA fastener has a book full of that stuff with pics that is local. One of the diesel boards had a part number as they did bosch to nippon swaps and dual alternator swaps.
Re: Denso Alternator terminals [Re: fourgearsavoy] #2993181
12/08/21 11:08 AM
12/08/21 11:08 AM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Gus beer
thank you very much for the offer Bu I am hell bent on finding the correct terminal as I am a bi anal about how I do things. And sometimes it becomes a challenge eyes beer
Re: Denso Alternator terminals [Re: 4406bbl] #2993195
12/08/21 11:35 AM
12/08/21 11:35 AM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Thank you as well and that is where I'm headed, I have the dimensions so hopefully that confirm or deny what i need wink
Re: Denso Alternator terminals [Re: TJP] #2993200
12/08/21 11:54 AM
12/08/21 11:54 AM
moparx Online content
moparx  Online Content
you don't want anything like this ? biggrin
beer
Re: Denso Alternator terminals [Re: TJP] #2993224
12/08/21 01:42 PM
12/08/21 01:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I agree, the typical insulated butt connectors are butt ugly so I've started using the non-insulated type covered with shrink wrap; not as ugly.
Re: Denso Alternator terminals [Re: John_Kunkel] #2993228
12/08/21 01:52 PM
12/08/21 01:52 PM
Guitar Jones Offline
Solder, heat shrink with sealer, harness tape and/or plastic conduit. Works for me, but I'm a function over form kind of guy.
Re: Denso Alternator terminals [Re: Guitar Jones] #2993287
12/08/21 05:23 PM
12/08/21 05:23 PM
IMGTX Offline
IMGTX  Offline
Me too.
Napa has a book of terminals and may have what you need or at least a way to look it up.
On a side note and the way I do it.
You have the terminal out. I have used pics and small screwdrivers to open terminals and remove the wire. I then reshape the terminal enough to get a crimp but solder it anyway.
Works like a charm with a little effort.
twocents
Re: Denso Alternator terminals [Re: IMGTX] #2993380
12/08/21 09:55 PM
12/08/21 09:55 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
thanks to all that replied. I finally found a source. Even the Toyota dealer didn't have them just a pigtail realcrazy With as common as the denso Alternators are I would've thought the terminals would be easily available. They have used a few different connectors over the years but these are pretty common yet harder than h-ll to find. If anyone else happens to be looking for them this place had them and a whole lot of others as well.
TERMINALS AND CONNECTORS LINKY
beer
Re: Denso Alternator terminals [Re: IMGTX] #2993383
12/08/21 09:58 PM
12/08/21 09:58 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Me too.
twocents
I have done that as well but these little xOB's are pretty fragile appearing, but that would've been a last resort wink
Re: Denso Alternator terminals [Re: moparx] #2993392
12/08/21 10:13 PM
12/08/21 10:13 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
beer
I've seen to many like that in the last 20 + years whistling
Re: Denso Alternator terminals [Re: John_Kunkel] #2993393
12/08/21 10:16 PM
12/08/21 10:16 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
When necessary I do the same using the sealing type shrink tube wink
Re: Denso Alternator terminals [Re: TJP] #2993480
12/09/21 07:49 AM
12/09/21 07:49 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We had those terminals by the roll at FCA. The connector hard shell may have a number stamped into it. That can be used to look up the proper terminal. We used U shaped splice clips.
https://www.newark.com/amp-te-connectivity/485043-1/terminal-open-barrel-splice-crimp/dp/33B9065?gclid=EAIaIQobChMIuMCv_dLW9AIVQfbjBx1PSQvsEAQYAiABEgLKPPD_BwE&mckv=s95bbt2s8_dc|pcrid|434136793404|plid||kword||match||slid||product|33B9065|pgrid|100464450466|ptaid|pla-985509465520|&CMP=KNC-GUSA-GEN-Shopping-NewStructure-Connectors
When used with this style w crimp tool the crimp is no bigger than the wire itself.
https://www.amazon.com/Qibaok-Ratcheting-0-5-1-5mm%C2%B2-Connectors-Terminals/dp/B07RZSSTSJ/ref=asc_df_B07RZSSTSJ/?tag=hyprod-20&linkCode=df0&hvadid=366281307321&hvpos=&hvnetw=g&hvrand=10762719042515110981&hvpone
Doug
Re: Denso Alternator terminals [Re: dvw] #2993574
12/09/21 12:32 PM
12/09/21 12:32 PM
