Page 1 of 3 1 2 3
lost cam lobe on break in twice #299209
04/25/09 07:46 PM
04/25/09 07:46 PM
Sharpsburg, GA
rusthole Offline OP
rusthole  Offline OP
Sharpsburg, GA
I have tried to break in a mopar 509 cam (with revised centerline)twice now, each time I wore the tip off a lobe. A different lobe each time. No oiling problems, followed all the breakin rules, used oil with zinc and lubed it properly, read previous posts about breakin proceedures.
My question- would I have better luck useing a different brand cam? Do some brands do better than others at breakin? What would be a comparable match in another brand?
Thanks in advance.....
Re: lost cam lobe on break in twice [Re: rusthole] #299210
04/25/09 07:51 PM
04/25/09 07:51 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
what are your open and seat pressures on srings and hieght. you might have too much spring for that cam
MOPAR OR NO CAR
Re: lost cam lobe on break in twice [Re: rusthole] #299211
04/25/09 07:52 PM
04/25/09 07:52 PM
If you took out the inner spring or if your spring pressure isn't too high I'd suspect the cam. I wont buy a MP cam(or valves) because of too many personal & purported failures.
Re: lost cam lobe on break in twice [Re: rusthole] #299212
04/25/09 07:52 PM
04/25/09 07:52 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
How tight do the lifters fit in the block? Are you lubing the bottom of the lifters and the lobes of the cam and if so what are you using?
Re: lost cam lobe on break in twice [Re: hemigod426] #299213
04/25/09 07:53 PM
04/25/09 07:53 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Been there, done that. Time for a roller.
Re: lost cam lobe on break in twice [Re: rusthole] #299214
04/25/09 07:53 PM
04/25/09 07:53 PM
west palm beach, florida
modelmakerinc Offline
Hi Rusthole,
sorry to say but it may be the cam material.
I wasted a MP 533 and I have a MP 509 going on me now. I am looking into a different brand Cam also I have not made up my mind so I'll follow this thread also
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: lost cam lobe on break in twice [Re: rusthole] #299215
04/25/09 07:56 PM
04/25/09 07:56 PM
hemisurfer Offline
hemisurfer  Offline
I am running a higher lift Comp Cams solid lifter in my 440 stroker and have had zero issues.
I am happy with Comp Cams, just a suggestion if your looking to switch to a another cam company.
Chris
Re: lost cam lobe on break in twice [Re: modelmakerinc] #299216
04/25/09 08:09 PM
04/25/09 08:09 PM
hemigod426 Offline
hemigod426  Offline
Hi Rusthole,
ive done rockwell harness tests on cam cores their ok it was all the newer lifters that are a joke. most cam corps use all the same blanks for cams. all the good lifter corps are gone. crower makes nice stuff still
MOPAR OR NO CAR
Re: lost cam lobe on break in twice [Re: rusthole] #299217
04/25/09 08:12 PM
04/25/09 08:12 PM
Sharpsburg, GA
rusthole Offline OP
rusthole  Offline OP
Sharpsburg, GA
I have the "hemi" springs rated to .500 lift, so I guess I am slightly weak with the springs. I lubed the lifters on the bottom and sides and made sure they spin looslely. I have a standard valvetrain. Maybe I should upgrade to solid lifters if that helps? Need to get this thing going!
Re: lost cam lobe on break in twice [Re: rusthole] #299218
04/25/09 08:16 PM
04/25/09 08:16 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
did all your lifters spin when you spun the cam buy hand? i do this with only light oil on the lifters and lobes.
Re: lost cam lobe on break in twice [Re: hemigod426] #299219
04/25/09 08:19 PM
04/25/09 08:19 PM
If the cam 's hardness is good but the lifters aren't then why does the cam lobe fail and not the lifter?
Re: lost cam lobe on break in twice [Re: ademon] #299220
04/25/09 08:24 PM
04/25/09 08:24 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
Sounds to me like you have a spring "coil bind" issue or the retainerss/keepers are hitting the valve guide. Did u make sure that your heads are set up to take the lift u are useing?.I would check this before putting a new cam in because u may just wipe out any brand if u have this problem and all the "modern" design cams have even more lift for the same duration.
Re: lost cam lobe on break in twice [Re: modelmakerinc] #299221
04/25/09 08:25 PM
04/25/09 08:25 PM
Sharpsburg, GA
rusthole Offline OP
rusthole  Offline OP
Sharpsburg, GA
I had the lifter bottom go concave on me both times as well
Re: lost cam lobe on break in twice [Re: rusthole] #299222
04/25/09 08:29 PM
04/25/09 08:29 PM
i had a mp cam in a dakota with a 5.2l that was professionally installed and broke in. i had mp springs and the other goodies put in with it and it wore off 2 lobes within 2000 miles. i put in a summit cam and have since sold the truck due to the frame rotting out but it has 40000 on the summit cam and runs like a dream. now its someones firewood truck.
Re: lost cam lobe on break in twice [Re: modelmakerinc] #299223
04/25/09 08:31 PM
04/25/09 08:31 PM
hemigod426 Offline
hemigod426  Offline
cam/lifter falure starts with metal transfer from lifter to lobe, like pepper grain size then cam acts like lathe and cuts them both to death
MOPAR OR NO CAR
Re: lost cam lobe on break in twice [Re: rusthole] #299224
04/25/09 08:47 PM
04/25/09 08:47 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Do not lube the sides of the lifters with the thick break in paste. The paste is for the lifter face and cam lobes only. If you put it on the sides it can prevent the lifters from spinning enough. Motor oil is all you need on the rest of the lifter and the lifter bores in the block.
There was a problem with bad lifters. Some were soft, some didn't have enough crown, some had the crown ground off center, and some were all of the above. If your lifters have been sitting on a dealers shelf for a few years, there's a good chance you got junk. I would only trust obviously very old lifters or very recent lifters.
Re: lost cam lobe on break in twice [Re: GomangoCuda] #299225
04/25/09 11:17 PM
04/25/09 11:17 PM
Az
Crizila Offline
Crizila  Offline
Az
Lifter rotation problem. Dirt in the lifter bores/galleys, scoring, wrong lube on lifter walls ( previously stated ). A good test: With the side of the lifters and lifter bores lubed with light oil, they should slide down the lifter bores with only their own weight. If you can't acheive this, you might want to rent a broach and broach the lifter bores - I think hughes rents them.
Fastest 300
Re: lost cam lobe on break in twice [Re: Crizila] #299226
04/26/09 10:04 AM
04/26/09 10:04 AM
I use WD40 & during mockup lift the lifters up off of the lobes w a finger & it should fall down onto the lobe under its own weight with a "thunk"
Re: lost cam lobe on break in twice [Re: rusthole] #299227
04/26/09 10:41 AM
04/26/09 10:41 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if those springs are set up for 1.88 installed heigth they will coil bind before .509 lift. those springs are obsolete.
Re: lost cam lobe on break in twice [Re: rusthole] #299228
04/26/09 10:54 AM
04/26/09 10:54 AM
I wouldn't, get a good cam & premium lifters(whatever these guys recommend) and a side note I always heard comp cams stuff was excellent but now I have heard of lifter problems with them
Page 1 of 3 1 2 3
