Re: lost cam lobe on break in twice
[Re: rusthole]
#299211
04/25/09 07:52 PM
04/25/09 07:52 PM
RapidRobert
If you took out the inner spring or if your spring pressure isn't too high I'd suspect the cam. I wont buy a MP cam(or valves) because of too many personal & purported failures.
[Re: rusthole]
#299215
04/25/09 07:56 PM
04/25/09 07:56 PM
Posts: 160 Florida
hemisurfer
I am running a higher lift Comp Cams solid lifter in my 440 stroker and have had zero issues.
I am happy with Comp Cams, just a suggestion if your looking to switch to a another cam company.
Chris
[Re: hemigod426]
#299219
04/25/09 08:19 PM
04/25/09 08:19 PM
Posts: 2,343 west palm beach, florida
modelmakerinc
ive done rockwell harness tests on cam cores their ok it was all the newer lifters that are a joke. most cam corps use all the same blanks for cams. all the good lifter corps are gone
If the cam 's hardness is good but the lifters aren't then why does the cam lobe fail and not the lifter?
[Re: rusthole]
#299222
04/25/09 08:29 PM
04/25/09 08:29 PM
i had a mp cam in a dakota with a 5.2l that was professionally installed and broke in. i had mp springs and the other goodies put in with it and it wore off 2 lobes within 2000 miles. i put in a summit cam and have since sold the truck due to the frame rotting out but it has 40000 on the summit cam and runs like a dream. now its someones firewood truck.
[Re: rusthole]
#299224
04/25/09 08:47 PM
04/25/09 08:47 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
I lubed the lifters on the bottom and sides and made sure they spin looslely.
Do not lube the sides of the lifters with the thick break in paste. The paste is for the lifter face and cam lobes only. If you put it on the sides it can prevent the lifters from spinning enough. Motor oil is all you need on the rest of the lifter and the lifter bores in the block.
There was a problem with bad lifters. Some were soft, some didn't have enough crown, some had the crown ground off center, and some were all of the above. If your lifters have been sitting on a dealers shelf for a few years, there's a good chance you got junk. I would only trust obviously very old lifters or very recent lifters.
[Re: GomangoCuda]
#299225
04/25/09 11:17 PM
04/25/09 11:17 PM
Posts: 7,506 Az
Crizila
Az
Lifter rotation problem. Dirt in the lifter bores/galleys, scoring, wrong lube on lifter walls ( previously stated ). A good test: With the side of the lifters and lifter bores lubed with light oil, they should slide down the lifter bores with only their own weight. If you can't acheive this, you might want to rent a broach and broach the lifter bores - I think hughes rents them.
Fastest 300
[Re: rusthole]
#299227
04/26/09 10:41 AM
04/26/09 10:41 AM
Posts: 3,916 usa
lewtot184
usa
I have the "hemi" springs rated to .500 lift, so I guess I am slightly weak with the springs. I lubed the lifters on the bottom and sides and made sure they spin looslely. I have a standard valvetrain. Maybe I should upgrade to solid lifters if that helps? Need to get this thing going!
if those springs are set up for 1.88 installed heigth they will coil bind before .509 lift. those springs are obsolete.
