Re: Tranzact of Indy Valvebody Issue [Re: pittsburghracer] #2991183
12/02/21 09:59 AM
12/02/21 09:59 AM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by pittsburghracer
Originally Posted by Transman
Originally Posted by J_BODY
I’m just surprised that nobody seems to know anything about him?
Maybe call TCI and see if they are back ordered on the Brake he makes for them.
If so maybe he is out of commission.
That doesn’t excuse him from not picking up the phone
Did I say to excuse him?
If TCI is behind then could be something besides him being a bad businessman.
Can’t pick up them phone or make product if he is in the hospital or worse.
I had a customer that got the same runaround from him on a gearset he makes that failed. He fixed it and said it would last all season. Failed in two passes.
Wouldn’t return the guys calls.
Re: Tranzact of Indy Valvebody Issue [Re: A727Tflite] #2991925
12/04/21 10:08 AM
12/04/21 10:08 AM
USA
CCG Offline
CCG  Offline
USA
Thanks Transman.
Re: Tranzact of Indy Valvebody Issue [Re: J_BODY] #2991927
12/04/21 10:10 AM
12/04/21 10:10 AM
USA
CCG Offline
CCG  Offline
USA
Thanks J Body.
I was hoping someone would know how to get in contact with him as well.
Merry Xmas.
Re: Tranzact of Indy Valvebody Issue [Re: pittsburghracer] #2991931
12/04/21 10:13 AM
12/04/21 10:13 AM
USA
CCG Offline
CCG  Offline
USA
Thanks Pittsburgracer.
I’m trying multiple avenues.
Merry Xmas.
Re: Tranzact of Indy Valvebody Issue [Re: tboomer] #2991932
12/04/21 10:15 AM
12/04/21 10:15 AM
USA
CCG Offline
CCG  Offline
USA
Originally Posted by tboomer
You have at least 25 posts on this subject. You should be contacting the Better Business Bureau,your credit card company or filing a claim in small claims court. Good luck as I hate to see somebody ripped off on race parts.
Thanks Tboomer.
Points taken.
I don’t want this to happen to anyone in this community either.
Merry Xmas.
Re: Tranzact of Indy Valvebody Issue [Re: CCG] #2991939
12/04/21 10:44 AM
12/04/21 10:44 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Merry Xmas.
Sorry that was aimed at Tranzact. They could pick up the phone and call YOU and explain why such a long delay.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Tranzact of Indy Valvebody Issue [Re: A727Tflite] #2992176
12/05/21 09:52 AM
12/05/21 09:52 AM
HR3128 Offline
HR3128  Offline
Quote
Look at the valve body - corner by the spring retainer bracket. There is a small long skinny spring next to the reg valve.
That’s the TCCV and spring. That’s your likely culprit. That valve should be all the way in it’s bore. And it should fall out once that bracket is removed.
Do you have a pic of the TCCV and spring location? I have a transmission with the same problem & thought I may mess with it over the winter. Thanks.
Re: Tranzact of Indy Valvebody Issue [Re: HR3128] #2992184
12/05/21 10:21 AM
12/05/21 10:21 AM
A727Tflite Offline
A727Tflite  Offline
Smack in the center of the picture - looks like a dumbbell. Has a skinny long spring holding it in.
Look for the black line to the left of the valve and spring.
Re: Tranzact of Indy Valvebody Issue [Re: A727Tflite] #2992187
12/05/21 10:41 AM
12/05/21 10:41 AM
HR3128 Offline
HR3128  Offline
Got it. Thanks. I appreciate the help.
