Re: New rear [Re: an8sec70cuda] #2969319
10/01/21 04:23 PM
10/01/21 04:23 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
NICE NEW ROLLERS TOO! Lookin' good!
"Any fool can know. The point is to understand"
- A. Einstein
Re: New rear [Re: EvilB1Dart] #2969323
10/01/21 04:28 PM
10/01/21 04:28 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Nice to see you guys making progress. I like his rearend. Lol 😂
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: New rear [Re: an8sec70cuda] #2969325
10/01/21 04:31 PM
10/01/21 04:31 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Originally Posted by an8sec70cuda
What wheels are those Tony? I like em.
Billet specialties . Rears are 15x12 I think they are 4” backspace . 10.5 x 29.5 bracket radials for now . This is going to be a street car / 10.0 index / pro dial bracket race car . ……. For now 😂
....BAD A$$ STREET CAR.....
Re: New rear [Re: n20mstr] #2969328
10/01/21 04:37 PM
10/01/21 04:37 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Purdy! up
Re: New rear [Re: gsmopar] #2969341
10/01/21 04:51 PM
10/01/21 04:51 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Nice Hinder. laugh2
I use the 9" in everything I build for play cars , and have no complaints.
Probably been a half dozen of them and I have yet to hurt one , from milder deals with 31 spline to 35 spline for the quicker cars.
Stock N cases at a minimum , but most got Strange with the 3.25 housing bore.
My first was an HRW case...........USA made back then.
But I don't think they are around anymore.
That was a hunk-o-iron.
Re: New rear [Re: tubtar] #2969363
10/01/21 05:50 PM
10/01/21 05:50 PM
lino lakes, mn
Schultz62 Offline
Schultz62  Offline
lino lakes, mn
Don't mind Cab with the Dana comment. He definitely know his stuff but is old school. That 9 inch is awesome. Just gotta say beat the hell out of it and report back
Re: New rear [Re: pittsburghracer] #2969609
10/02/21 12:11 PM
10/02/21 12:11 PM
moparx Online content
moparx  Online Content
eek eek tsk whistling devil stirthepot biggrin
i couldn't help it !
beer
Re: New rear [Re: moparx] #2969628
10/02/21 01:48 PM
10/02/21 01:48 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Nice up I may be moving to a 9" soon. Just can't seem to find pro gears in 3.91 or below for a Dana frown
Re: New rear [Re: Schultz62] #2969633
10/02/21 01:54 PM
10/02/21 01:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
I can remember when the Chrisman brothers had Jim Dunn and Joe Reath do the initial 9.0 inch rear end R&D on their old rear engine funny car back in the late 1970 and early 1980s, some one at Petersen publishing group heard about that and thought they would make news out of that effort hence all the chatter about the magical Ford nine inch rea end down twocents
I look at the 8.0% larger ring gear diameter and the larger tooth to pinion teeth contact as well as the reduce drag on the Dana 60 as well as the 40 spline axles
and lesser costs as my reasons to continue use them up
I'm old school I am and I'm not looking to waste my race car budget either up work A stock dana 60 housing with 3.0, 3 1/8 or the larger H.D. 3.250 diameter axles will take a lot more power than any stock Ford nine housing will take scope Why spend a $1000.00+ for a good after market 9 inch housing when a stock junk yard Dana 60 will live for you work
Dana 60 live long and go faster boogie grin up
Re: New rear [Re: Cab_Burge] #2970201
10/04/21 08:21 AM
10/04/21 08:21 AM
an8sec70cuda Offline
Monte Smith always said that eventually you get to the point where you start bending housings...with a Dana, there's nothing you can do to stop it.
This is less likely to happen with really narrow housings like on a big tire car (depending on the power level of course). On a small tire car w/ stock style suspension (wide housing), especially on a drag radial, this is more of an issue.
I talked this over w/ him and he advised me to keep an eye on the housing and when (not if) it bends, to bite the bullet and change rears. Keep in mind, he's not talking about a 700 hp bracket car on slicks.
Every part of a race 9" is aftermarket, so the stock 9" strength argument need not apply here.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New rear [Re: an8sec70cuda] #2970209
10/04/21 08:34 AM
10/04/21 08:34 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Looking good Tony!
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: New rear [Re: an8sec70cuda] #2970219
10/04/21 08:46 AM
10/04/21 08:46 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I am still running a Dana 60 in my Challenger. However, mine is an old 1 ton Dodge Ram axle I cut down and narrowed. They have thicker wall tubes. If I remember correctly they are 3/8" or 1/2" wall thickness. Also added ultra light weight spool, 40 spine gun drilled axles with 5/8" studs. Billet custom made caps and girdle support rear cover as well as additional structured welded/bracing to housing. Going to be hard to break or bend it.
Funny thing is all of my buddies that run 9" never swap the center sections once a gear ratio is chosen, so the simplicity of just being able to swap center sections never helps.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: New rear [Re: 11secdart] #2970221
10/04/21 08:49 AM
10/04/21 08:49 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Looks great,,,,,,,Daddy! grin
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New rear [Re: Cab_Burge] #2970374
10/04/21 01:36 PM
10/04/21 01:36 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Challengers Dana didn't last long when we started getting it to hook laugh blush
Re: New rear [Re: Tig] #2970596
10/04/21 10:05 PM
10/04/21 10:05 PM
We all know then Brits can screw up a 50 ton wrecking ball in a sandbox with feather haha Just kidding grin
My 2850 Lb. S/P Cuda has hundreds of runs on the used 4:56 Dana brand pickup gears running in the high eights at 148+ MPH shruggy
Different folks get different results shruggy work
Re: New rear [Re: Cab_Burge] #2970624
10/04/21 11:24 PM
10/04/21 11:24 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Nice upgrade. Probably the majority of modified Mopars over here in Australia have 9" rears.
Dana 60 and 8 3/4" rears and their parts aren't everywhere, and in most cases parts are a special order.
Alan Jones
Re: New rear [Re: Cab_Burge] #2970909
10/05/21 12:56 PM
10/05/21 12:56 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
True on both counts grin grin. Challenger is over 4000lbs and to be fair, it was a set of street gears that bust.
