Disassembling Paintable Door Mirrors #2969047
10/01/21 08:32 AM
10/01/21 08:32 AM
Spanaway, Washington State
P
patosmith Offline OP
P
So, I bought a set of paintable bullet door mirrors for my 72 Challenger.
I want to disassemble them so I can get them painted.
Does anyone know how to get the mirror out of the housing so the inside can get painted?
I can get to the 2 screws that hold the base to the housing but I don't know how to remove the mirror itself.
If I turn the mirror, I can see screws in the housing but there is no way to get a screwdriver on them.
Does the mirror just pop out or am I missing something?
Re: Disassembling Paintable Door Mirrors [Re: patosmith] #2969173
10/01/21 12:09 PM
10/01/21 12:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A recent issue of Mopar Action covered this; IIRC the glass had to be broken out to access the interior.
Re: Disassembling Paintable Door Mirrors [Re: John_Kunkel] #2969197
10/01/21 12:29 PM
10/01/21 12:29 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
Don't break your mirror glass. Bend a slim phillips head screw driver just enough to clear the mirror to access the screws that hold the adjusting mechanism to the outer housing. I've removed several mirror plates this way for painting. You may have to spray some penetrating oil and let it sit before attempting this. These are after all 50 years old in most cases! You DO NOT want to strip the head of the screw! Take your time and use steady pressure. Good luck.
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: Disassembling Paintable Door Mirrors [Re: patosmith] #2969264
10/01/21 02:01 PM
10/01/21 02:01 PM
Missouri
randavis Offline
randavis  Offline
Missouri
I've read somewhere that you can immerse them in acetone and it will dissolve the adhesive on the mirror.
I have not tried it, but it sounds reasonable to me.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Disassembling Paintable Door Mirrors [Re: randavis] #2969270
10/01/21 02:09 PM
10/01/21 02:09 PM
P
P
Thanks to everyone for the info.
I will do the screw driver trick to take them apart. This is a new repop set and I hoped there would be an easier way to take them apart.
Thanks again.
Re: Disassembling Paintable Door Mirrors [Re: patosmith] #2969326
10/01/21 04:31 PM
10/01/21 04:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Can't you get away with taping the mirror and painting?
Re: Disassembling Paintable Door Mirrors [Re: stumpy] #2969373
10/01/21 06:45 PM
10/01/21 06:45 PM
U code RR Offline
U code RR  Offline
If the re-pops are like the OEM mirrors, you are going to have tape the mirror and cable after you pull it through far enough to get paint inside the housing if it is a driver side adjustable mirror. You can't get the adjuster mechanism through the mirror housing. The individual adjuster cables are swedged on after the cable is inserted through the mirror housing. Good Luck, just take your time, you'll be fine.
Re: Disassembling Paintable Door Mirrors [Re: U code RR] #2969376
10/01/21 07:10 PM
10/01/21 07:10 PM
U code RR Offline
U code RR  Offline
I found my screw driver that I modified. Here are some pics. Hope this helps.
Re: Disassembling Paintable Door Mirrors [Re: U code RR] #2969428
10/01/21 08:54 PM
10/01/21 08:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up beer
Re: Disassembling Paintable Door Mirrors [Re: TJP] #2970365
10/04/21 01:28 PM
10/04/21 01:28 PM
GA
roadrunninMark Offline
GA
Stumpy's idea is good so you don't ding the fresh paint trying to put it back together.
Re: Disassembling Paintable Door Mirrors [Re: John_Kunkel] #2970388
10/04/21 02:04 PM
10/04/21 02:04 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yes the mirror baseplate get the holes for those screws BUT IF the screws are not stuck buy dust/rust, it could be done like shown with a modified screwdriver or:
Re: Disassembling Paintable Door Mirrors [Re: roadrunninMark] #2970549
10/04/21 08:30 PM
10/04/21 08:30 PM
Maryland
MoparMike1974 Offline
Maryland
Re: Disassembling Paintable Door Mirrors [Re: NachoRT74] #2970554
10/04/21 08:46 PM
10/04/21 08:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'd go with U code RR's approach if trying to take them apart as his tool would likely give much better leverage and control. When reassembling tape the areas off with 2 0r 3 layers of painters tape to prevent damage.
or as Stumpy suggested, tape off the mirror
I have also had luck with the acetone, Shallow pan with enough Acetone to submerge the mirror +1/2" or so. best if you can somehow cover it to contain the fumes and prevent the evaporation. Tin foil would work well.
last, call the supplier/ manufacturer. let us know what works for you beer
Re: Disassembling Paintable Door Mirrors [Re: TJP] #2970593
10/04/21 10:02 PM
10/04/21 10:02 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
I've used a heat gun and dental floss to remove exterior nameplates. You heat the nameplate and then 'saw' through the adhesive with the floss. It might be possible to do the same thing with the mirror glass.
