What are you using for oil in your 4 speed? #2967812
09/27/21 01:00 PM
09/27/21 01:00 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
I have a 1971 833 23 spline 4-speed 340 car. My trans up shifts great, but have a tough time down shifting. I am currently using 85W-90 gear oil compatible with brass stop rings. The coldest temperature that I would drive it would be 50 degrees and the warmest would be 90 degrees.
I was wondering if auto trans fluid would make it down shift easier.
Re: What are you using for oil in your 4 speed? [Re: ragtop] #2967814
09/27/21 01:04 PM
09/27/21 01:04 PM
IMGTX Offline
IMGTX  Offline
I used to run Gear oil in the summer and auto transmission in the winter and occasionally a mix if the shift wasn't to my liking.
The old 833's like a good fluid but are pretty flexible.
Re: What are you using for oil in your 4 speed? [Re: ragtop] #2967825
09/27/21 01:31 PM
09/27/21 01:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Redline 75W-90NS synthetic.
Re: What are you using for oil in your 4 speed? [Re: ragtop] #2967840
09/27/21 02:13 PM
09/27/21 02:13 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I think I've used 85W-90 once year round, I just switched back to 85W-140. Below freezing it's like trying to stir molasses? until the trans warms up some. But it still shifts fine on the road. I put 37,000+ miles with RedLine 75W-90 NS. All that being said, I've never noticed a significant difference between any of the fluids. It might shift "better" now with the 85W-140, maybe I don't know how to drive shruggy drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: What are you using for oil in your 4 speed? [Re: ragtop] #2967858
09/27/21 02:58 PM
09/27/21 02:58 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
. If it up shifts okay but hard down shifting, the brass rings are probably gone and need replaced. Auto transmission fluid will make it shift easier, if everything was okay before you put the ATF in. If everything was not okay, then I doubt it will make a difference. If you want to try a different fluid, try 2 1/2 qts of regular engine oil. Maybe like a 30 weight. It is GL 4 like ATF and syncro oils.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: What are you using for oil in your 4 speed? [Re: 68LAR] #2967861
09/27/21 03:04 PM
09/27/21 03:04 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
This is correct.
Re: What are you using for oil in your 4 speed? [Re: Cuda340] #2967930
09/27/21 06:50 PM
09/27/21 06:50 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Pennzoil Synchromesh.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: What are you using for oil in your 4 speed? [Re: mopardude318] #2968000
09/27/21 09:23 PM
09/27/21 09:23 PM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
85W-90 here. No problems and smooooth shifting!
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: What are you using for oil in your 4 speed? [Re: Plum440] #2968010
09/27/21 10:02 PM
09/27/21 10:02 PM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
The tired (I guess) 833 in my road runner did not shift as silky smooth as I would have liked when using 90 weight. I put ATF in it and it made a small difference. It did leak slightly with the thinner ATF though.
Re: What are you using for oil in your 4 speed? [Re: Ramrod39] #2968046
09/28/21 05:19 AM
09/28/21 05:19 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I tried Amzoil synthetic in mine and it would not shift well at all. Went back the the lighter 85-90w and it went back to shifting fine.
Re: What are you using for oil in your 4 speed? [Re: ragtop] #2968074
09/28/21 09:08 AM
09/28/21 09:08 AM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
I use the oil Jamie Passon sells in my 833 4-speed
Re: What are you using for oil in your 4 speed? [Re: ragtop] #2968092
09/28/21 10:21 AM
09/28/21 10:21 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Re: What are you using for oil in your 4 speed? [Re: 451Mopar] #2968133
09/28/21 12:24 PM
09/28/21 12:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've been running 85/90W GL-4 for the last 42 years in my Challenger T/A.... I change it out about every 10 years
Re: What are you using for oil in your 4 speed? [Re: DAYCLONA] #2968575
09/29/21 06:54 PM
09/29/21 06:54 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Another vote for Pennzoil Synchromesh here.
drive
Re: What are you using for oil in your 4 speed? [Re: DrCharles] #2968593
09/29/21 07:45 PM
09/29/21 07:45 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
StaLube 85-90 GL-4
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: What are you using for oil in your 4 speed? [Re: 70sixpkrt] #2968754
09/30/21 12:47 PM
09/30/21 12:47 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Another Pennzoil Synchromesh user . drive But when I ONLY want Mopar Fluid in my MOPAR's the Manual Tranny Lube Part # 0487446AB also works Great , just like the Pennzoil . Olanturn
Re: What are you using for oil in your 4 speed? [Re: DrCharles] #2968781
09/30/21 02:22 PM
09/30/21 02:22 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
drive
Same here.
Re: What are you using for oil in your 4 speed? [Re: 451Mopar] #2968798
09/30/21 03:27 PM
09/30/21 03:27 PM
AndyF Offline
AndyF  Offline
Originally Posted by 451Mopar
I've been using MTL for years in my Coronet. Seems to work okay.
Re: What are you using for oil in your 4 speed? [Re: GomangoCuda] #2969292
10/01/21 03:23 PM
10/01/21 03:23 PM
an8sec70cuda Offline
Pennzoil synchromesh in the my dad's 4 speed six pack road runner. Works great.
CHIP
'06 GMC 2500HD LBZ Duramax
