What are you using for oil in your 4 speed?
#2967812
09/27/21 01:00 PM
09/27/21 01:00 PM
Posts: 1,619 MA
ragtop
MA
I have a 1971 833 23 spline 4-speed 340 car. My trans up shifts great, but have a tough time down shifting. I am currently using 85W-90 gear oil compatible with brass stop rings. The coldest temperature that I would drive it would be 50 degrees and the warmest would be 90 degrees. I was wondering if auto trans fluid would make it down shift easier.
Re: What are you using for oil in your 4 speed?
[Re: ragtop]
#2967825
09/27/21 01:31 PM
09/27/21 01:31 PM
Posts: 25,783 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Redline 75W-90NS synthetic.
[Re: ragtop]
#2967858
09/27/21 02:58 PM
09/27/21 02:58 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I have a 1971 833 23 spline 4-speed 340 car. My trans up shifts great, but have a tough time down shifting. I am currently using 85W-90 gear oil compatible with brass stop rings. The coldest temperature that I would drive it would be 50 degrees and the warmest would be 90 degrees. I was wondering if auto trans fluid would make it down shift easier. . If it up shifts okay but hard down shifting, the brass rings are probably gone and need replaced. Auto transmission fluid will make it shift easier, if everything was okay before you put the ATF in. If everything was not okay, then I doubt it will make a difference. If you want to try a different fluid, try 2 1/2 qts of regular engine oil. Maybe like a 30 weight. It is GL 4 like ATF and syncro oils.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2967861
09/27/21 03:04 PM
09/27/21 03:04 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
I have a 1971 833 23 spline 4-speed 340 car. My trans up shifts great, but have a tough time down shifting. I am currently using 85W-90 gear oil compatible with brass stop rings. The coldest temperature that I would drive it would be 50 degrees and the warmest would be 90 degrees. I was wondering if auto trans fluid would make it down shift easier. . If it up shifts okay but hard down shifting, the brass rings are probably gone and need replaced. Auto transmission fluid will make it shift easier, if everything was okay before you put the ATF in. If everything was not okay, then I doubt it will make a difference. If you want to try a different fluid, try 2 1/2 qts of regular engine oil. Maybe like a 30 weight. It is GL 4 like ATF and syncro oils. This is correct.
[Re: mopardude318]
#2968000
09/27/21 09:23 PM
09/27/21 09:23 PM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
85W-90 here. No problems and smooooth shifting!
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
[Re: GomangoCuda]
#2969292
10/01/21 03:23 PM
10/01/21 03:23 PM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
Pennzoil synchromesh in the my dad's 4 speed six pack road runner. Works great.
