Who would run P2Vs this tight? #2965163
09/18/21 04:18 AM
09/18/21 04:18 AM
Detroit, MI
CokeBottleKid Offline OP
Detroit, MI
Anyone? laugh
Intake is on the left, exhaust is on the right.
5.2 magnum with mild cam... stock pistons
Re: Who would run P2Vs this tight? [Re: CokeBottleKid] #2965198
09/18/21 09:16 AM
09/18/21 09:16 AM
Washington
madscientist Offline
Washington
Originally Posted by CokeBottleKid
Anyone? laugh
I have run much tighter than that, with an engine that shifted at 8500. Send it.
Re: Who would run P2Vs this tight? [Re: CokeBottleKid] #2965199
09/18/21 09:36 AM
09/18/21 09:36 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Race build ok. gear/belt drive,even better
Something your building for a couple of hundred thousand trouble free miles not so much. When the timing chain stretches, exhaust is gonna hit. I have seen stock 318's with shinny spots when they are wore out.
Re: Who would run P2Vs this tight? [Re: B1MAXX] #2965201
09/18/21 09:49 AM
09/18/21 09:49 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Yes
Doug
Re: Who would run P2Vs this tight? [Re: dvw] #2965216
09/18/21 11:25 AM
09/18/21 11:25 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Stock Magnum heads are done at 5800-6100 , Intake valves chase the piston so they good, Exh at .090 is good
....BAD A$$ STREET CAR.....
Re: Who would run P2Vs this tight? [Re: B1MAXX] #2965352
09/18/21 07:58 PM
09/18/21 07:58 PM
Detroit, MI
Detroit, MI
Noted.... it does have a brand new double roller tho so hopefully will be good for a while.
Re: Who would run P2Vs this tight? [Re: n20mstr] #2965353
09/18/21 08:01 PM
09/18/21 08:01 PM
Detroit, MI
Detroit, MI
It'd be nice to use all that RPM, but with a 216/224 @.050 cam on a 114 LSA I doubt we'll peak past 5500..... wish I coulda found a tighter LSA and had more P2V for more duration. I should mention these numbers are with the timing set retarded 4 degrees... it had .032" intake clearance with it installed at 109... it's at 113 now.
Re: Who would run P2Vs this tight? [Re: CokeBottleKid] #2965357
09/18/21 08:10 PM
09/18/21 08:10 PM
Your good as far as I'm concern, I run them tighter than this with good parts and check every valve to piston scopeup
