Who would run P2Vs this tight?
#2965163
09/18/21 04:18 AM
09/18/21 04:18 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Anyone? Intake is on the left, exhaust is on the right. 5.2 magnum with mild cam... stock pistons
Re: Who would run P2Vs this tight?
[Re: CokeBottleKid]
#2965198
09/18/21 09:16 AM
09/18/21 09:16 AM
Posts: 4,457 Washington
madscientist
Washington
Anyone? Intake is on the left, exhaust is on the right. 5.2 magnum with mild cam... stock pistons I have run much tighter than that, with an engine that shifted at 8500. Send it.
[Re: B1MAXX]
#2965201
09/18/21 09:49 AM
09/18/21 09:49 AM
Posts: 9,846 MI, usa
dvw
MI, usa
[Re: dvw]
#2965216
09/18/21 11:25 AM
09/18/21 11:25 AM
Posts: 4,682 On the parachute mount
n20mstr
Stock Magnum heads are done at 5800-6100 , Intake valves chase the piston so they good, Exh at .090 is good
....BAD A$$ STREET CAR.....
[Re: B1MAXX]
#2965352
09/18/21 07:58 PM
09/18/21 07:58 PM
CokeBottleKid
Detroit, MI
Race build ok. gear/belt drive,even better
Something your building for a couple of hundred thousand trouble free miles not so much. When the timing chain stretches, exhaust is gonna hit. I have seen stock 318's with shinny spots when they are wore out. Noted.... it does have a brand new double roller tho so hopefully will be good for a while.
[Re: n20mstr]
#2965353
09/18/21 08:01 PM
09/18/21 08:01 PM
CokeBottleKid
Detroit, MI
It'd be nice to use all that RPM, but with a 216/224 @.050 cam on a 114 LSA I doubt we'll peak past 5500..... wish I coulda found a tighter LSA and had more P2V for more duration. I should mention these numbers are with the timing set retarded 4 degrees... it had .032" intake clearance with it installed at 109... it's at 113 now.
