440 Six Pack w/Factory Max Wedge Heads
#2962389
09/09/21 07:30 AM
09/09/21 07:30 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Just curious if anyone has ever build a 440 Six Pack with factory Max Wedge heads? I've often wondered what could have been if Chrysler would have continued those heads for production use on the 440's later on.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
Re: 440 Six Pack w/Factory Max Wedge Heads
[Re: ChrgrCuda]
#2962637
09/10/21 02:40 AM
09/10/21 02:40 AM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
The Edelbrock sixpack intake will require welding and porting to work with max wedge heads. Indy sells their Modman intake with max wedge ports.
[Re: GomangoCuda]
#2962645
09/10/21 08:14 AM
09/10/21 08:14 AM
ChrgrCuda
Texas, USA
The Edelbrock sixpack intake will require welding and porting to work with max wedge heads. Indy sells their Modman intake with max wedge ports. That's good to know Gomango. Thank you. I am using a factory 1969 Six Pack/Barrel intake, so I really don't want to hack it up. Looks like I will just try to find a nice set of used ported 906 heads that I can go through to match with the cam. Thanks again!
[Re: BigBlockGTS]
#2962663
09/10/21 09:52 AM
09/10/21 09:52 AM
ChrgrCuda
Texas, USA
ChrgrCuda- There is a company in Kansas (KC Engines?) that does CNC porting of iron heads with pretty good flow numbers at a very reasonable price. Get a good set of cores and let 'er rip. The 440 Source Heads look like factory castings if you want to go that route. That's awesome! I will look them up! Thank you!!
[Re: ChrgrCuda]
#2962775
09/10/21 07:39 PM
09/10/21 07:39 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
The Edelbrock sixpack intake will require welding and porting to work with max wedge heads. Indy sells their Modman intake with max wedge ports. That's good to know Gomango. Thank you. I am using a factory 1969 Six Pack/Barrel intake, so I really don't want to hack it up. Looks like I will just try to find a nice set of used ported 906 heads that I can go through to match with the cam. Thanks again! Wow, no offense, but this thread left me disappointed. After reading that cool sounding title and now reading the decision to just run cast iron heads turned out pretty anti-climactic. I was hoping to see you get into the weeds with a full rework an aluminum six pack manifold, so it would bolt up to some Max Wedge port heads and make some serious horsepower. Good luck either way.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: ChrgrCuda]
#2962797
09/10/21 08:48 PM
09/10/21 08:48 PM
Posts: 494 IL
EchoSixMike
IL
[Re: ChrgrCuda]
#2962862
09/11/21 08:55 AM
09/11/21 08:55 AM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Looking back and thinking "What if." What if Mopar would have continued the max wedge heads on a 440. Another option - lower in cost to the top option Hemi but more powerful than the 906 headed 440 magnum. So from the factory an optional 440 Max wedge with big cam and increased power above the 440 magnum- a direct lower cost option (Compared to th Hemi) competitor to the LS-6 Chevy offering.
Keep old mopars alive.
[Re: EchoSixMike]
#2962866
09/11/21 09:05 AM
09/11/21 09:05 AM
2boltmain
Holland MI Ottawa
Impressive work they do. They show a pic of an iron LA and RB head in their slideshow.
[Re: 2boltmain]
#2962895
09/11/21 10:48 AM
09/11/21 10:48 AM
Posts: 14,505 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
As has been mentioned, the easiest(best?) way to run a 6bbl on MW heads is to use the appropriate ModMan intake from Indy.
Even after welding up the port flanges on a std 6bbl manifold, the runners themselves are way smaller than the MW heads, so the intake would be holding back the heads from making all the power they could.
Having the MW sized heads is only 1/2 of the combination......... you need the true MW sized intake to go with them.
[Re: ChrgrCuda]
#2962898
09/11/21 10:53 AM
09/11/21 10:53 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The Edelbrock sixpack intake will require welding and porting to work with max wedge heads. Indy sells their Modman intake with max wedge ports. That's good to know Gomango. Thank you. I am using a factory 1969 Six Pack/Barrel intake, so I really don't want to hack it up. Looks like I will just try to find a nice set of used ported 906 heads that I can go through to match with the cam. Thanks again! If you are going with iron go with a set of 915's. as Mentioned 440 source heads are "factory" cast so they will work to, plus they are aluminum.
[Re: 2boltmain]
#2963909
09/14/21 07:33 AM
09/14/21 07:33 AM
ChrgrCuda
Texas, USA
Looking back and thinking "What if." What if Mopar would have continued the max wedge heads on a 440. Another option - lower in cost to the top option Hemi but more powerful than the 906 headed 440 magnum. So from the factory an optional 440 Max wedge with big cam and increased power above the 440 magnum- a direct lower cost option (Compared to th Hemi) competitor to the LS-6 Chevy offering. My point exactly. Thank you sir!
[Re: fast68plymouth]
#2963910
09/14/21 07:36 AM
09/14/21 07:36 AM
ChrgrCuda
Texas, USA
Thanks Dwayne. That was why I asked the question. You pretty much pointed out the reason I guess why nobody does this combination. My point in using factory stuff was just that...what could be accomplished. Not what or how much better aftermarket Indy or any other aluminum heads and intake would be. Just factory stuff.
