440 Six Pack w/Factory Max Wedge Heads #2962389
09/09/21 07:30 AM
09/09/21 07:30 AM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Just curious if anyone has ever build a 440 Six Pack with factory Max Wedge heads? I've often wondered what could have been if Chrysler would have continued those heads for production use on the 440's later on.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: ChrgrCuda] #2962396
09/09/21 07:45 AM
09/09/21 07:45 AM
E
earlymopar Offline
earlymopar  Offline
E
Let me know if you're interested in a set.
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: ChrgrCuda] #2962637
09/10/21 02:40 AM
09/10/21 02:40 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The Edelbrock sixpack intake will require welding and porting to work with max wedge heads. Indy sells their Modman intake with max wedge ports.
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: GomangoCuda] #2962645
09/10/21 08:14 AM
09/10/21 08:14 AM
Texas, USA
Texas, USA
That's good to know Gomango. Thank you. I am using a factory 1969 Six Pack/Barrel intake, so I really don't want to hack it up. Looks like I will just try to find a nice set of used ported 906 heads that I can go through to match with the cam. Thanks again!
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: ChrgrCuda] #2962653
09/10/21 09:21 AM
09/10/21 09:21 AM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
ChrgrCuda- There is a company in Kansas (KC Engines?) that does CNC porting of iron heads with pretty good flow numbers at a very reasonable price. Get a good set of cores and let 'er rip. The 440 Source Heads look like factory castings if you want to go that route.
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: BigBlockGTS] #2962663
09/10/21 09:52 AM
09/10/21 09:52 AM
Texas, USA
Texas, USA
That's awesome! I will look them up! Thank you!!
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: ChrgrCuda] #2962775
09/10/21 07:39 PM
09/10/21 07:39 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Wow, no offense, but this thread left me disappointed. After reading that cool sounding title and now reading the decision to just run cast iron heads turned out pretty anti-climactic. I was hoping to see you get into the weeds with a full rework an aluminum six pack manifold, so it would bolt up to some Max Wedge port heads and make some serious horsepower. Good luck either way.
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: ChrgrCuda] #2962797
09/10/21 08:48 PM
09/10/21 08:48 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
https://kgengines.wixsite.com/kgengines
That's Kansas Ohio. S/F....Ken M
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: jbc426] #2962844
09/11/21 01:50 AM
09/11/21 01:50 AM
I'm thinking the stock type six pack intake will limit the power compare to other induction systems including on Max Wedge port size heads, my old pump gas car started off with 906 heads a on a 505 C.I. low deck with Eddy low deck six pack intake and modified 440 six pack carbs. I did a bunch of part tetsing on the car and motor and ended up making it run from 10.69 at 124. MPH down to 10.teens at 127 MPH with 440 size intake ports and that intake and carbs, switch to a set of Indy SR M.W. port heads with a Indy 400-3 intake and a 1050 CFM Holley Dominator carb and it ran 9.993 at 134.+ MPH with no other changes shruggy
A tunnel ram intake with two 1050 made 30 HP more on the same engine on the engine dyno compared to the single dominator set up work
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: ChrgrCuda] #2962862
09/11/21 08:55 AM
09/11/21 08:55 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Looking back and thinking "What if." What if Mopar would have continued the max wedge heads on a 440. Another option - lower in cost to the top option Hemi but more powerful than the 906 headed 440 magnum. So from the factory an optional 440 Max wedge with big cam and increased power above the 440 magnum- a direct lower cost option (Compared to th Hemi) competitor to the LS-6 Chevy offering.
Keep old mopars alive.
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: EchoSixMike] #2962866
09/11/21 09:05 AM
09/11/21 09:05 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Impressive work they do. They show a pic of an iron LA and RB head in their slideshow.
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: 2boltmain] #2962895
09/11/21 10:48 AM
09/11/21 10:48 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
As has been mentioned, the easiest(best?) way to run a 6bbl on MW heads is to use the appropriate ModMan intake from Indy.
Even after welding up the port flanges on a std 6bbl manifold, the runners themselves are way smaller than the MW heads, so the intake would be holding back the heads from making all the power they could.
Having the MW sized heads is only 1/2 of the combination......... you need the true MW sized intake to go with them.
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: ChrgrCuda] #2962898
09/11/21 10:53 AM
09/11/21 10:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you are going with iron go with a set of 915's. as Mentioned 440 source heads are "factory" cast so they will work to, plus they are aluminum.
Coming soon!!!!
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: Mr.Yuck] #2962928
09/11/21 12:08 PM
09/11/21 12:08 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
If a stock look isn't important the TF 240 heads are about the best heads that work with a stock port.
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: 2boltmain] #2963909
09/14/21 07:33 AM
09/14/21 07:33 AM
Texas, USA
Texas, USA
My point exactly. Thank you sir!
Re: 440 Six Pack w/Factory Max Wedge Heads [Re: fast68plymouth] #2963910
09/14/21 07:36 AM
09/14/21 07:36 AM
Texas, USA
Texas, USA
Thanks Dwayne. That was why I asked the question. You pretty much pointed out the reason I guess why nobody does this combination. My point in using factory stuff was just that...what could be accomplished. Not what or how much better aftermarket Indy or any other aluminum heads and intake would be. Just factory stuff.
