HOW to remove stud from from hub?? Drum brakes HELP!!
#295060
04/21/09 12:34 PM
04/21/09 12:34 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Trying to remove a broken stud from front hub. I have the hub separated from the drum, and can tap the stud ALMOST through, from front to back. But once the knurl is about halfway through the hub, it stops SOLID. I can move the stud back and forth easily, but once it's half way through, it will not go any further. Am I missing something here? codfish
Re: HOW to remove stud from from hub?? Drum brakes HE
[Re: codfish]
#295066
04/21/09 01:25 PM
04/21/09 01:25 PM
Posts: 75,077 U.S.S.A.
JohnRR
U.S.S.A.
thanks again
Well that was easy
codfish
done already ???
[Re: codfish]
#295067
04/21/09 01:27 PM
04/21/09 01:27 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
This is a classic 'opinions vary' question. Although I agree that there is a swage in there, I've never had one that didn't come out with a few smacks from a 2-lb hammer.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#295068
04/21/09 03:17 PM
04/21/09 03:17 PM
Yeah, well, I've followed around behind "you" a few times, and doing this often enlarges the hole enough that a new stud won't fit tight, either
[Re: Twostick]
#295070
04/21/09 06:20 PM
04/21/09 06:20 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
If it didn't enlarge the hole when it was installed new, I would think it should "uninstall" the same way.
Kevin
The stud is swaged after it is installed in the hub & the drum is installed...
[Re: John_Kunkel]
#295072
04/21/09 07:53 PM
04/21/09 07:53 PM
Here's a pic of a stud installed before (right) and after (left) swaging; the swaging process does enlarge the shank, so driving the stud out without removing the swaging does indeed risk enlarging the hole.
Exactly correct. They work just like a rivet.
[Re: John_Kunkel]
#295074
04/22/09 12:35 PM
04/22/09 12:35 PM
BRawls
super gas
super gas
Dang John, your depth of knowledge and the pictures to back it up is astonishing. You have forgotten more than I'll ever know...
[Re: BRawls]
#295075
04/22/09 10:14 PM
04/22/09 10:14 PM
codfish
Newfoundland
I was thinking the same thing!!
codfish
