HOW to remove stud from from hub?? Drum brakes HELP!! #295060
04/21/09 12:34 PM
04/21/09 12:34 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Trying to remove a broken stud from front hub.
I have the hub separated from the drum, and can tap the stud ALMOST through, from front to back. But once the knurl is about halfway through the hub, it stops SOLID.
I can move the stud back and forth easily, but once it's half way through, it will not go any further.
Am I missing something here?
codfish
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: codfish] #295061
04/21/09 12:40 PM
04/21/09 12:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
front studs are swaged to hold the drum on , you got the drum off how ? the swage needs to be ground down to get the stud out
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: JohnRR] #295062
04/21/09 12:45 PM
04/21/09 12:45 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Actually the drum separated from the hub pretty easily.
With the drum on the work bench, hub still attached and lug nuts on the stubs, tapped on the four remaining studs and it came apart.
These swages, are they a separate piece, or is the stud's knurls "swollen" to creat the swage?
thanks John.
codfish
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: codfish] #295063
04/21/09 12:48 PM
04/21/09 12:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the studs is swollen to create the swage . tap the stud back into place and cut what is remaining off just off the hub , should pop right out .
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: JohnRR] #295064
04/21/09 12:51 PM
04/21/09 12:51 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Thanks sir.
I'll give it a try.
gary
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: codfish] #295065
04/21/09 01:10 PM
04/21/09 01:10 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
thanks again
Well that was easy
codfish
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: codfish] #295066
04/21/09 01:25 PM
04/21/09 01:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks again
Well that was easy
codfish
done already ???
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: codfish] #295067
04/21/09 01:27 PM
04/21/09 01:27 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
This is a classic 'opinions vary' question.
Although I agree that there is a swage in there, I've never had one that didn't come out with a few smacks from a 2-lb hammer.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: Fury Fan] #295068
04/21/09 03:17 PM
04/21/09 03:17 PM
Yeah, well, I've followed around behind "you" a few times, and doing this often enlarges the hole enough that a new stud won't fit tight, either
Re: HOW to remove stud from from hub?? Drum brakes HE #295069
04/21/09 06:17 PM
04/21/09 06:17 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If it didn't enlarge the hole when it was installed new, I would think it should "uninstall" the same way.
Kevin
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: Twostick] #295070
04/21/09 06:20 PM
04/21/09 06:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Kevin
The stud is swaged after it is installed in the hub & the drum is installed...
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: Twostick] #295071
04/21/09 07:30 PM
04/21/09 07:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of a stud installed before (right) and after (left) swaging; the swaging process does enlarge the shank, so driving the stud out without removing the swaging does indeed risk enlarging the hole.
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: John_Kunkel] #295072
04/21/09 07:53 PM
04/21/09 07:53 PM
Exactly correct. They work just like a rivet.
Re: HOW to remove stud from from hub?? Drum brakes HE #295073
04/22/09 01:08 AM
04/22/09 01:08 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The day wasn't a waste after all. I learned something. (again!)
Kevin
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: John_Kunkel] #295074
04/22/09 12:35 PM
04/22/09 12:35 PM
BRawls Offline
super gas
BRawls  Offline
super gas
Dang John, your depth of knowledge and the pictures to back it up is astonishing. You have forgotten more than I'll ever know...
Re: HOW to remove stud from from hub?? Drum brakes HE [Re: BRawls] #295075
04/22/09 10:14 PM
04/22/09 10:14 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
I was thinking the same thing!!
codfish
