I need a manual steering box for my 83 Cordoba....
#294628
04/21/09 02:10 AM
04/21/09 02:10 AM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
So I can fit the Big Block in with headers! Did the F-body aspens and volares have manual steering boxes?? Or would a box from an A-body fit????? TIA TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
Re: I need a manual steering box for my 83 Cordoba....
[Re: 446acuda]
#294631
04/21/09 04:53 PM
04/21/09 04:53 PM
tpabayflyer
Tampa, FL
Thanks guys...I need to get rid of the stupid, huge rag joint as well so I will weld in some kind of coupler and bypass that ripoff power/manual adapter deal..... I also bought the solid aluminum body bushings from cudazappa and they are awesome!! I also plan on running an electric water pump in the big block sothats another reason the power steering has to go.... TBF
[Re: tpabayflyer]
#294632
04/21/09 05:47 PM
04/21/09 05:47 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
check to see if flaming river has something to eliminate the rag joint , they do have a direct coupler for the manual box.
[Re: MOPARS6768]
#294635
04/21/09 06:35 PM
04/21/09 06:35 PM
tpabayflyer
Tampa, FL
I might be interested in the box and the lower part up to the rag joint..... I'll send you an email. I was not sure if the f-body's used manual steering or not. I had an old 80 aspen with a slant 6 and it was power..... TBF
