I need a manual steering box for my 83 Cordoba....
#294628
04/21/09 02:10 AM
04/21/09 02:10 AM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
So I can fit the Big Block in with headers! Did the F-body aspens and volares have manual steering boxes?? Or would a box from an A-body fit????? TIA TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
Re: I need a manual steering box for my 83 Cordoba....
[Re: 446acuda]
#294631
04/21/09 04:53 PM
04/21/09 04:53 PM
tpabayflyer
Tampa, FL
Thanks guys...I need to get rid of the stupid, huge rag joint as well so I will weld in some kind of coupler and bypass that ripoff power/manual adapter deal..... I also bought the solid aluminum body bushings from cudazappa and they are awesome!! I also plan on running an electric water pump in the big block sothats another reason the power steering has to go.... TBF
[Re: tpabayflyer]
#294632
04/21/09 05:47 PM
04/21/09 05:47 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
check to see if flaming river has something to eliminate the rag joint , they do have a direct coupler for the manual box.
[Re: 1_WILD_RT]
#294633
04/21/09 05:47 PM
04/21/09 05:47 PM
JohnRR
U.S.S.A.
A,B & E manual boxes all have the same mounting design as your Cordoba, a B/E body pitman arm will interchange with your stock pitman arm & you'll need the adapter to connect your steering shaft to the manual box...
The adapter is shown in this link..
http://cgi.ebay.com/ebaymotors/NEW-MOPAR...4QQcmdZViewItem
But the price they are asking is crazy, that part use to sell for $45.00 but when I searched there were three vendors selling it & they are all
Better but still...
http://chucker54.stores.yahoo.net/mamastad.html
Now that it's NS! from the dealer the price has gone thru the roof on that .
[Re: MOPARS6768]
#294635
04/21/09 06:35 PM
04/21/09 06:35 PM
tpabayflyer
Tampa, FL
I might be interested in the box and the lower part up to the rag joint..... I'll send you an email. I was not sure if the f-body's used manual steering or not. I had an old 80 aspen with a slant 6 and it was power..... TBF
