440 source fluid dampers....any good? #294562
04/20/09 11:31 PM
04/20/09 11:31 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Anybody out there using one of these with good results?
Re: 440 source fluid dampers....any good? [Re: domingo] #294563
04/20/09 11:38 PM
04/20/09 11:38 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
i would dig through a 6 foot deep box full of new 440 source dampers to find a original cruddy looking damper at the bottom, to go on my stock 383 2 barrel daily driver.
Re: 440 source fluid dampers....any good? [Re: Bob_Coomer] #294564
04/20/09 11:41 PM
04/20/09 11:41 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Care to discuss why, for those of us not 'in the know?'
Re: 440 source fluid dampers....any good? [Re: mopowers] #294565
04/21/09 12:02 AM
04/21/09 12:02 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I put one on my 383 stroker. I've had it for 3 years, and put about a total of 3000 miles, plus a dyno session spinning it up to 6500 rpm a bunch of times, and it seems to be doing ok for me
**Photobucket sucks**
Re: 440 source fluid dampers....any good? [Re: 70Cuda383] #294566
04/21/09 12:03 AM
04/21/09 12:03 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
The only thing I didn't like about it, was that the timing marks are only "printed" on the outside of it, so when I painted it with the rest of my engine, I lost the timing marks. not that big of a deal, it's pretty easy to find TDC and re-mark it after painting.
Re: 440 source fluid dampers....any good? [Re: 70Cuda383] #294567
04/21/09 01:00 AM
04/21/09 01:00 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm using one. can you say "tight fit"? it'll never fall off thats for sure.
Re: 440 source fluid dampers....any good? [Re: rebel] #294568
04/21/09 03:58 AM
04/21/09 03:58 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
that's for sure! I spent probably 20? maybe 30? minutes with some emery cloth to open mine up a little bit, and it was still very tight!
Re: 440 source fluid dampers....any good? [Re: 70Cuda383] #294569
04/21/09 08:16 AM
04/21/09 08:16 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I ran a small hone through mine to take the plating out of the center hole,it fits about right now.
I have been running one on a stock crank 440 for a few years now,up to 7000 rpm through the traps.
I can't say if it is good or bad,but I will be buying another one.
Re: 440 source fluid dampers....any good? [Re: domingo] #294570
04/21/09 08:49 AM
04/21/09 08:49 AM
North Branch, MI, USA
notchbackcuda Offline
I run one on my barracuda: 499 stroker approx 620hp.
270 passes and no problems yet. Yeah, they are very tight on the crankshaft.
Re: 440 source fluid dampers....any good? [Re: notchbackcuda] #294571
04/21/09 10:09 AM
04/21/09 10:09 AM
Big Island ,VA
JC Childress Offline
Big Island ,VA
we had a customer we built an engine for, and he supplied us with one of these and it spun the whole outer ring off after just a few passes. in my opinion, just get an ATI and be done with it !
J.C. Childress (434) 665-9541
Re: 440 source fluid dampers....any good? [Re: JC Childress] #294572
04/21/09 02:32 PM
04/21/09 02:32 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I guess that wowuld have been the 2 piece unit with a rubber insulator....right?
The fluid damper doesnt have an "outer ring" or does it?
Re: 440 source fluid dampers....any good? [Re: domingo] #294573
04/21/09 02:55 PM
04/21/09 02:55 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Go ATI and be done with it.
Re: 440 source fluid dampers....any good? [Re: Michael] #294574
04/21/09 03:56 PM
04/21/09 03:56 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
there is a past thread here baout one going real bad for a customer...
Mopar Performance
Re: 440 source fluid dampers....any good? [Re: domingo] #294575
04/22/09 10:07 AM
04/22/09 10:07 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I have had one on my stroker for two years with no problems,If you put it on with out sizing it to the crank dia first, it was to high tech of a job for you to do.
Re: 440 source fluid dampers....any good? [Re: moparniac] #294576
04/22/09 08:56 PM
04/22/09 08:56 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
there is a past thread here about one going real bad for a customer...
That was me. The damper failed and the Source didn't care. I have a Pioneer now and it is a much nicer looking unit all the way around. And not much more money. We'll see how it holds up.
Master, again and still
Re: 440 source fluid dampers....any good? [Re: DaveRS23] #294577
04/22/09 09:03 PM
04/22/09 09:03 PM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
havnt had any problems with mine yet. 440 ballanced 275 shot spinning 7500rpm
