Ati balancer hits timing cover #293988
04/20/09 04:33 PM
04/20/09 04:33 PM
Vidor Texas
O
onyxba Offline OP
onyxba  Offline OP
O
Vidor Texas
On a big block with a gear drive and an aluminum timing cover, the Ati balancer hits the timing cover before it botoms against the crank gear. Can i take the stock balancer and cut the hub to make a crank spacer. Has anybody had this problem. Thanks in advance for suggestions.
Post deleted by Defbob [Re: onyxba] #293989
04/20/09 04:38 PM
04/20/09 04:38 PM
Re: Ati balancer hits timing cover #293990
04/20/09 04:57 PM
04/20/09 04:57 PM
Vidor Texas
O
onyxba Offline OP
onyxba  Offline OP
O
Vidor Texas
Thanks Fred called ATI they say they have 2 length hubs, and that they would be more than happy to sell me a hub for $130. I asked if i could cut the old balancer and do like i suggest and he said no but that he would also be happy to sell me the spacers that they offer. ATI tech support sounds more like sales guy.
Re: Ati balancer hits timing cover [Re: onyxba] #293991
04/20/09 06:26 PM
04/20/09 06:26 PM
AndyF Online content
AndyF  Online Content
Just swap to the longer ATI hub. Your pulley alignment will be way off but such is life.
The longer hub is also required when using a Jesel belt drive. I had to swap my ATI damper over to the longer hub when I installed the belt drive.
Re: Ati balancer hits timing cover [Re: onyxba] #293992
04/20/09 06:30 PM
04/20/09 06:30 PM
oregon
savoyracer Offline
savoyracer  Offline
oregon
Same problem here, Machinist simply made the spacer, and everything is fine. Sounds like a little "GOUGING" is going on.
Re: Ati balancer hits timing cover [Re: savoyracer] #293993
04/20/09 06:44 PM
04/20/09 06:44 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have on occasion used a spacer.I don't know where we got them but they are aprox..200 thick with the notch for the keyway.I think I may have a few around.
Re: Ati balancer hits timing cover [Re: B G Racing] #293994
04/20/09 07:06 PM
04/20/09 07:06 PM
SD USA
neonic Offline
neonic  Offline
SD USA
I had the same issue called ATI and they sent me 2 spacers for free. I think they were .090 thick each if I remember correct.
Re: Ati balancer hits timing cover [Re: onyxba] #293995
04/20/09 07:10 PM
04/20/09 07:10 PM
richmond indiana
I
ichsam Offline
ichsam  Offline
I
richmond indiana
indy sells spacers for this
Re: Ati balancer hits timing cover [Re: ichsam] #293996
04/20/09 08:32 PM
04/20/09 08:32 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Your right Sam,I probably got them from you. The ones we got from you are aprox..095 thick,the .200 came from Keith Black long ago.
