Ati balancer hits timing cover #293988
04/20/09 04:33 PM
04/20/09 04:33 PM
Vidor Texas
O
onyxba Offline OP
onyxba  Offline OP
O
Vidor Texas
On a big block with a gear drive and an aluminum timing cover, the Ati balancer hits the timing cover before it botoms against the crank gear. Can i take the stock balancer and cut the hub to make a crank spacer. Has anybody had this problem. Thanks in advance for suggestions.
Post deleted by Defbob [Re: onyxba] #293989
04/20/09 04:38 PM
04/20/09 04:38 PM
Re: Ati balancer hits timing cover #293990
04/20/09 04:57 PM
04/20/09 04:57 PM
Vidor Texas
O
onyxba Offline OP
onyxba  Offline OP
O
Vidor Texas
Thanks Fred called ATI they say they have 2 length hubs, and that they would be more than happy to sell me a hub for $130. I asked if i could cut the old balancer and do like i suggest and he said no but that he would also be happy to sell me the spacers that they offer. ATI tech support sounds more like sales guy.
Re: Ati balancer hits timing cover [Re: onyxba] #293991
04/20/09 06:26 PM
04/20/09 06:26 PM
AndyF Offline
AndyF  Offline
Just swap to the longer ATI hub. Your pulley alignment will be way off but such is life.
The longer hub is also required when using a Jesel belt drive. I had to swap my ATI damper over to the longer hub when I installed the belt drive.
Re: Ati balancer hits timing cover [Re: onyxba] #293992
04/20/09 06:30 PM
04/20/09 06:30 PM
oregon
savoyracer Offline
savoyracer  Offline
oregon
Same problem here, Machinist simply made the spacer, and everything is fine. Sounds like a little "GOUGING" is going on.
Re: Ati balancer hits timing cover [Re: savoyracer] #293993
04/20/09 06:44 PM
04/20/09 06:44 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have on occasion used a spacer.I don't know where we got them but they are aprox..200 thick with the notch for the keyway.I think I may have a few around.
Re: Ati balancer hits timing cover [Re: B G Racing] #293994
04/20/09 07:06 PM
04/20/09 07:06 PM
SD USA
neonic Offline
neonic  Offline
SD USA
I had the same issue called ATI and they sent me 2 spacers for free. I think they were .090 thick each if I remember correct.
Re: Ati balancer hits timing cover [Re: onyxba] #293995
04/20/09 07:10 PM
04/20/09 07:10 PM
richmond indiana
I
ichsam Offline
ichsam  Offline
I
richmond indiana
indy sells spacers for this
Re: Ati balancer hits timing cover [Re: ichsam] #293996
04/20/09 08:32 PM
04/20/09 08:32 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Your right Sam,I probably got them from you. The ones we got from you are aprox..095 thick,the .200 came from Keith Black long ago.
