Radiator feedback , Wizard /Speedcooling(ECP) #2938119
06/29/21 05:53 PM
06/29/21 05:53 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Has anyone used the Wizard or ECP/Speedcooling radiators ?
ECP - https://speedcooling.com/26-Big-Block-Mopar-Radiator.html
Wizard - https://wizardcooling.com/1966-1969-26-b-b-mopar-applications-aluminum-radiator/
What has been your experience ? Quality , lifespan , actual cooling ?
I run a 505 BB , 650ish HP 11.0:1 . In a 1968 Plymouth Satellite . Currently using a AFCO radiator , temp sits 195/200 . This worked fine on my factory block 440 and 505 but the World block definately runs warmer . I run factory shroud , 5 blade clutch fan plus a manual control 14"elec pusher fan .
It looks like the Wizard/ECP has about 448 square inches surface are compared to about 427 sq" with the AFCO . So not sure if there is enough gained for the cost , i do have to import the radiator and pay in Aussie pesos .
Thanks in advance ,
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: tex013] #2938128
06/29/21 06:13 PM
06/29/21 06:13 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
there is a school of thought that says 1 square inch of radiator core for each cubic inch of displacement, minimum.
Stock 68 383 radiator core is at 455 sq in.
You might want to double check your math, I get 487 sq in for the ECP unit, wizard doesn't appear to give the core dimensions.
No idea how the row count might affect the equation though.
Here's a link to some interesting info
https://www.pirate4x4.com/threads/r...fiecincy-aluminium-vs-brass-tech.250185/
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: Sniper] #2938129
06/29/21 06:18 PM
06/29/21 06:18 PM
N
NITROUSN Offline
NITROUSN  Offline
N
No help on what you are looking at. On my 528 Hemi with a/c I have a Cold Case with dual pullers and I was very happy on how cool it runs.
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: NITROUSN] #2938133
06/29/21 06:40 PM
06/29/21 06:40 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the ECP in my 68 Charger 512 cid, COLD A/C , car runs 185ish all day long with the A/C on, down here in HOT Southeast Texas.
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: tex013] #2938160
06/29/21 08:08 PM
06/29/21 08:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Does it maintain at 195 -200 under all conditions? What's the ambient temp. Does it run warmer at slow speeds. Have you verified the temperature with a thermocouple & digital meter ?
IMO There are a ton of variables involved and more information is needed before jumping on the radiator replacement.
twocents beer
popcorn
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: TJP] #2938163
06/29/21 08:28 PM
06/29/21 08:28 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks guys .
maybe my maths is not so good grin .
I expect Wizard is same size as stock , same as ECP . but hey ive been wrong before . They list it as factory size replacement for a 26".
Temp goes up and sits 195/200 ish even on freeway . Whether warm or cool , on cold days it is a little cooler .
I have checked with a temperature gun and it shows the heat like gauge , yes it does show a ok drop across core .
This is the 2nd AFCO i have fitted . First was in for 10 + (?) years . At start of year fan grabbed it at the strip . So i bought same unit plus a NOS ( same part number ) Mopar 5 blade fan . I do have the Jaguar short fan hub . It is 3/4"off core half in half out of shroud , shroud sealed to radiator .
CSK , i know that Texas weather , not dissimilar to here in Sydney .
Tex
PS : i have not used a tsat for at 12 years . As i race a lot and dont feel its advisable to be high rpm with a shut tstat if you cant get up to temp quick .
New best MPH 130.32
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: tex013] #2938183
06/29/21 09:19 PM
06/29/21 09:19 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted by tex013
thanks guys .
Tex
the Jag clutch would not keep my car running cool,it is not HD this is what worked great
Flex-a-lite 101571 - Flex-A-Lite 7-Blade Fans
Fan, Flex-Type, 7-Blade, Clockwise, 18.25 in. Diameter, Stainless Steel Blades/Steel Hub, Universal, Each, very well made high rpm blade, I now have electric fans & they work great also,
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: CSK] #2938199
06/29/21 10:21 PM
06/29/21 10:21 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
CSK ,
i did have the mopar clutch hub , came with 5 blade as performance kit , but i cannot fit it now . I had maybe 3/8"clearance before . With new radiator and new side mounts it is barely 1/4"now .
Funny i have a 17"flex a lite fan i tried , but not real keen on that on the strip .
Its just one of those things , is it bad ? not totally . Could it be better , yes . Ideally i would like 190 freeway max
I could try the VP Stay Frosty complete coolant mix . I know some guys having good results with that .
I do quite a few highway miles and daily drive it .
thanks
Tex
New best MPH 130.32
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: tex013] #2938238
06/30/21 12:31 AM
06/30/21 12:31 AM
MN
W
Willie68coronet Offline
W
MN
I use this one auto city classic radiator .
Looks similar to the Ecp. But looks closer to a stock radiator. I use it with a shroud, 6 blade 18 inch flex fan, high volume mancini water pump, 160 Milodon stat and vacuum advance never see more than 180ish- maybe 185 idling or cruising. Without vacuum advance it got up to 200-210 at 70 mph 3500rpm.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: Willie68coronet] #2938246
06/30/21 03:43 AM
06/30/21 03:43 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thanks for the link , at least they are happy to ship .
I never really had issues till using the World block .
Tex
New best MPH 130.32
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: tex013] #2938312
06/30/21 11:49 AM
06/30/21 11:49 AM
moparx Offline
moparx  Offline
have you thought about maybe going to a good dual puller electric fan setup ?
your pusher fan may be blocking some airflow. shruggy
just a thought from an old forgetful guy.
beer
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: Willie68coronet] #2938400
06/30/21 03:28 PM
06/30/21 03:28 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Does the stock shroud fit?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: moparx] #2938456
06/30/21 05:47 PM
06/30/21 05:47 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
beer
yes i have tried that , used an Aust Ford Falcon unit .
Never had an issue till the World block , maybe a little worse again since having to fit the Jaf fan hub
Tex
New best MPH 130.32
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: tex013] #2938518
06/30/21 09:25 PM
06/30/21 09:25 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The 2947 Hayden is a short HD fan clutch for a mopar
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: CSK] #2938530
06/30/21 09:55 PM
06/30/21 09:55 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks
I have the 2765
Tex
New best MPH 130.32
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: tex013] #2938566
06/30/21 11:16 PM
06/30/21 11:16 PM
USA
hudsonhornet7x Offline
USA
I have a 26" Wizard and am very happy with it. Never overheats and the fit and finish is better than most of the aluminum radiators out there.
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: hudsonhornet7x] #2938569
06/30/21 11:28 PM
06/30/21 11:28 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks
Tex
New best MPH 130.32
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: tex013] #2938577
06/30/21 11:50 PM
06/30/21 11:50 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
I have a Wizard all be it a 22" version with shroud for a stock 7 blade fan.
I had to send the rad back twice for repairs. The billet filler neck was cracked on the inside where the vented cap seals when I got it, send it back they welded a new neck on put it in filled it and it leaked like a sieve. Sent it back again and its been good since then.
As far as cooling I think I should have just stuffed a 26" rad it as it will still push to 205 when on a hot day ins top and go traffic.
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: 340SIX] #2938623
07/01/21 08:43 AM
07/01/21 08:43 AM
MN
W
W
MN
I have a newer mopar performance shroud that bolted right to it. Not sure how close to stock my shroud is though.
Re: Radiator feedback , Wizard /Speedcooling(ECP) [Re: tex013] #2938667
07/01/21 10:58 AM
07/01/21 10:58 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
As a side comment,
I had a vehicle years back that was all new mechanically, the motor was brand new (not rebuilt) as was the 4 row (staggered) copper brass radiator, factory pulleys, shroud, etc. It was basically all stock with no modifications. It ran 195 - 200 no matter what the speed was, the ambient temp, idling for extended periods, A/C on or off, didn't matter nor did anything i tried. After about 2 years it was totaled as it was just an old car of no real value at the time (would've been fixed today).
gauge accuracy was verified with a laboratory grade meter and thermocouple placed right next to the thermostat. the hottest it ever registered was 205 on a 100 degree day idling in traffic for 1/2 hour or so with the A/C on.
I just wanted to throw that out there for thought.
