Radiator feedback , Wizard /Speedcooling(ECP)
#2938119
06/29/21 05:53 PM
06/29/21 05:53 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
Has anyone used the Wizard or ECP/Speedcooling radiators ? ECP - https://speedcooling.com/26-Big-Block-Mopar-Radiator.htmlWizard - https://wizardcooling.com/1966-1969-26-b-b-mopar-applications-aluminum-radiator/What has been your experience ? Quality , lifespan , actual cooling ? I run a 505 BB , 650ish HP 11.0:1 . In a 1968 Plymouth Satellite . Currently using a AFCO radiator , temp sits 195/200 . This worked fine on my factory block 440 and 505 but the World block definately runs warmer . I run factory shroud , 5 blade clutch fan plus a manual control 14"elec pusher fan . It looks like the Wizard/ECP has about 448 square inches surface are compared to about 427 sq" with the AFCO . So not sure if there is enough gained for the cost , i do have to import the radiator and pay in Aussie pesos . Thanks in advance , Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Radiator feedback , Wizard /Speedcooling(ECP)
[Re: tex013]
#2938128
06/29/21 06:13 PM
06/29/21 06:13 PM
Posts: 6,290 nowhere
Sniper
nowhere
there is a school of thought that says 1 square inch of radiator core for each cubic inch of displacement, minimum. Stock 68 383 radiator core is at 455 sq in. You might want to double check your math, I get 487 sq in for the ECP unit, wizard doesn't appear to give the core dimensions. No idea how the row count might affect the equation though. Here's a link to some interesting info https://www.pirate4x4.com/threads/r...fiecincy-aluminium-vs-brass-tech.250185/
[Re: NITROUSN]
#2938133
06/29/21 06:40 PM
06/29/21 06:40 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
I have the ECP in my 68 Charger 512 cid, COLD A/C , car runs 185ish all day long with the A/C on, down here in HOT Southeast Texas.
[Re: TJP]
#2938163
06/29/21 08:28 PM
06/29/21 08:28 PM
tex013
Sydney,Australia
thanks guys . maybe my maths is not so good . I expect Wizard is same size as stock , same as ECP . but hey ive been wrong before . They list it as factory size replacement for a 26". Temp goes up and sits 195/200 ish even on freeway . Whether warm or cool , on cold days it is a little cooler . I have checked with a temperature gun and it shows the heat like gauge , yes it does show a ok drop across core . This is the 2nd AFCO i have fitted . First was in for 10 + (?) years . At start of year fan grabbed it at the strip . So i bought same unit plus a NOS ( same part number ) Mopar 5 blade fan . I do have the Jaguar short fan hub . It is 3/4"off core half in half out of shroud , shroud sealed to radiator . CSK , i know that Texas weather , not dissimilar to here in Sydney . Tex PS : i have not used a tsat for at 12 years . As i race a lot and dont feel its advisable to be high rpm with a shut tstat if you cant get up to temp quick .
[Re: tex013]
#2938183
06/29/21 09:19 PM
06/29/21 09:19 PM
CSK
Pattison Texas
thanks guys . maybe my maths is not so good . I expect Wizard is same size as stock , same as ECP . but hey ive been wrong before . They list it as factory size replacement for a 26". Temp goes up and sits 195/200 ish even on freeway . Whether warm or cool , on cold days it is a little cooler . I have checked with a temperature gun and it shows the heat like gauge , yes it does show a ok drop across core . This is the 2nd AFCO i have fitted . First was in for 10 + (?) years . At start of year fan grabbed it at the strip . So i bought same unit plus a NOS ( same part number ) Mopar 5 blade fan . I do have the Jaguar short fan hub . It is 3/4"off core half in half out of shroud , shroud sealed to radiator . CSK , i know that Texas weather , not dissimilar to here in Sydney . Tex PS : i have not used a tsat for at 12 years . As i race a lot and dont feel its advisable to be high rpm with a shut tstat if you cant get up to temp quick . the Jag clutch would not keep my car running cool,it is not HD this is what worked great Flex-a-lite 101571 - Flex-A-Lite 7-Blade Fans Fan, Flex-Type, 7-Blade, Clockwise, 18.25 in. Diameter, Stainless Steel Blades/Steel Hub, Universal, Each, very well made high rpm blade, I now have electric fans & they work great also,
[Re: CSK]
#2938199
06/29/21 10:21 PM
06/29/21 10:21 PM
tex013
Sydney,Australia
CSK , i did have the mopar clutch hub , came with 5 blade as performance kit , but i cannot fit it now . I had maybe 3/8"clearance before . With new radiator and new side mounts it is barely 1/4"now . Funny i have a 17"flex a lite fan i tried , but not real keen on that on the strip . Its just one of those things , is it bad ? not totally . Could it be better , yes . Ideally i would like 190 freeway max I could try the VP Stay Frosty complete coolant mix . I know some guys having good results with that . I do quite a few highway miles and daily drive it .
thanks
Tex
[Re: tex013]
#2938238
06/30/21 12:31 AM
06/30/21 12:31 AM
Posts: 277 MN
Willie68coronet
MN
I use this one auto city classic radiator . Looks similar to the Ecp. But looks closer to a stock radiator. I use it with a shroud, 6 blade 18 inch flex fan, high volume mancini water pump, 160 Milodon stat and vacuum advance never see more than 180ish- maybe 185 idling or cruising. Without vacuum advance it got up to 200-210 at 70 mph 3500rpm.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: Willie68coronet]
#2938246
06/30/21 03:43 AM
06/30/21 03:43 AM
tex013
Sydney,Australia
Thanks for the link , at least they are happy to ship . I never really had issues till using the World block .
Tex
#2938400
06/30/21 03:28 PM
06/30/21 03:28 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I use this one auto city classic radiator . Looks similar to the Ecp. But looks closer to a stock radiator. I use it with a shroud, 6 blade 18 inch flex fan, high volume mancini water pump, 160 Milodon stat and vacuum advance never see more than 180ish- maybe 185 idling or cruising. Without vacuum advance it got up to 200-210 at 70 mph 3500rpm. Does the stock shroud fit?
[Re: moparx]
#2938456
06/30/21 05:47 PM
06/30/21 05:47 PM
tex013
Sydney,Australia
have you thought about maybe going to a good dual puller electric fan setup ? your pusher fan may be blocking some airflow. just a thought from an old forgetful guy. yes i have tried that , used an Aust Ford Falcon unit . Never had an issue till the World block , maybe a little worse again since having to fit the Jaf fan hub Tex
[Re: tex013]
#2938518
06/30/21 09:25 PM
06/30/21 09:25 PM
CSK
Pattison Texas
The 2947 Hayden is a short HD fan clutch for a mopar
[Re: CSK]
#2938530
06/30/21 09:55 PM
06/30/21 09:55 PM
tex013
Sydney,Australia
thanks I have the 2765
Tex
[Re: 340SIX]
#2938623
07/01/21 08:43 AM
07/01/21 08:43 AM
Posts: 277 MN
Willie68coronet
MN
I use this one auto city classic radiator . Looks similar to the Ecp. But looks closer to a stock radiator. I use it with a shroud, 6 blade 18 inch flex fan, high volume mancini water pump, 160 Milodon stat and vacuum advance never see more than 180ish- maybe 185 idling or cruising. Without vacuum advance it got up to 200-210 at 70 mph 3500rpm. Does the stock shroud fit? I have a newer mopar performance shroud that bolted right to it. Not sure how close to stock my shroud is though.
[Re: tex013]
#2938667
07/01/21 10:58 AM
07/01/21 10:58 AM
Posts: 15,438 Omaha Ne
TJP
Omaha Ne
As a side comment, I had a vehicle years back that was all new mechanically, the motor was brand new (not rebuilt) as was the 4 row (staggered) copper brass radiator, factory pulleys, shroud, etc. It was basically all stock with no modifications. It ran 195 - 200 no matter what the speed was, the ambient temp, idling for extended periods, A/C on or off, didn't matter nor did anything i tried. After about 2 years it was totaled as it was just an old car of no real value at the time (would've been fixed today). gauge accuracy was verified with a laboratory grade meter and thermocouple placed right next to the thermostat. the hottest it ever registered was 205 on a 100 degree day idling in traffic for 1/2 hour or so with the A/C on. I just wanted to throw that out there for thought.
